Kawasaki ER-6F Self Check
Steven8294
PostPosted: 21:57 - 02 Mar 2013    Post subject: Kawasaki ER-6F Self Check Reply with quote
Hi All,
I have a small issue with my bike, as I am sure most of you are aware if you turn on some of the newer bikes they do a self diagnostics run, making like a clicking and buzzing noise. Only on my ER-6F the bike makes this noise but quieter even when the electrics are off and the immobiliser is on (and when its off). The noise comes from the tank area, can anyone tell me what this is? I am planning on taking into shop if noone has seen this before.
This noise is made for around 10 seconds every few minute or so.
Thanks
| Passed; 14th November 2012 | 1st Bike: Yamaha YBR125 2009 Model |
| 2nd Bike: 09 Kawasaki ER-6F (Stolen) | Current Bike: 08 Kawasaki ER-6N
barrkel
PostPosted: 22:12 - 02 Mar 2013    Post subject: Re: Kawasaki ER-6F Self Check Reply with quote
A slight buzzing for a few seconds every now and then? It is almost certainly petrol vapour escaping from the tank cap seal. The cap is designed to let the vapour out, otherwise pressure would build up when it's hot out. Much more frequent when it's a sunny day, or the engine is hot.
Steven8294
PostPosted: 22:19 - 02 Mar 2013    Post subject: Re: Kawasaki ER-6F Self Check Reply with quote
Really? I took the bike out of the garage this morning and it was doing it almost instantly. Could it still be this?
PostPosted: 22:21 - 02 Mar 2013    Post subject: Reply with quote
It's the bomb that's connected to the immobiliser arming itself.
If someone tries to hot wire your bike. BOOM.
I wouldn't expect vapour escaping to make a buzzing noise.....sounds like it would be a fuel pump, but this would only prime when you turn the key.
moonzoomer
PostPosted: 22:45 - 02 Mar 2013    Post subject: Reply with quote
That will be your fuel pump.
PostPosted: 22:46 - 02 Mar 2013    Post subject: Reply with quote
Even when the bike's turned off?
moonzoomer
PostPosted: 22:48 - 02 Mar 2013    Post subject: Reply with quote
Yes
PostPosted: 22:53 - 02 Mar 2013    Post subject: Reply with quote
moonzoomer wrote:
Yes
Why would it be designed to do that??
moonzoomer
PostPosted: 22:55 - 02 Mar 2013    Post subject: Reply with quote
moonzoomer wrote:
Yes
apparently it has something to do with the fuel injection system, I have noticed a fair few posts on several forums regarding this noise.
barrkel
PostPosted: 23:27 - 02 Mar 2013    Post subject: Reply with quote
It makes a kind of high-pitched buzzing noise on my ER6. A bit like a mosquito near your ear, only louder, and coming from the tank cap area. If I'm working on the bike in the summer, it happens frequently.
I think you're that's referring to the noise when you turn the ignition to on; a kind of whirring for ~1 second. I believe that's the fuel pump.
moonzoomer
PostPosted: 23:35 - 02 Mar 2013    Post subject: Reply with quote
apparently the pump does not need the ignition switched on with this model, thats what others have told me anyway which has to do with keeping the injectors at constant pressure. I could be wrong but it makes sense in a way.
TomGT
PostPosted: 23:37 - 02 Mar 2013    Post subject: Reply with quote
so the fuel pump primes itself, even when the bike is off? Sounds like you've got a serious fire hazard in the event of a fuel leak... Shocked
1992 ZXR 400
barrkel
PostPosted: 02:13 - 03 Mar 2013    Post subject: Reply with quote
I think moonzoomer is mistaken, without authoritative references to back him up. The buzzing doesn't sound anything like the ignition on noise. It's quieter and far higher pitched.
Steven8294
PostPosted: 12:42 - 03 Mar 2013    Post subject: Reply with quote
All,
Im going to do the self diagnosis today see if that returns any errors. If not ill try to record the sound for you all to hear.
Ed Case
PostPosted: 21:33 - 03 Mar 2013    Post subject: Reply with quote
It's the expansion/contraction of the fuel in the tank with air escaping via the filler..........mine does it all the time !.
PostPosted: 23:52 - 03 Mar 2013    Post subject: Reply with quote
Crap, so what happens if you have an empty tank, the pump buzzes away until it self destructs?
Triumph Trophy Launch Edition
Walloper
PostPosted: 09:27 - 04 Mar 2013    Post subject: Reply with quote
There are two coil units under the tank, airbox etc. On top of the spark plugs. You may be hearing the current in the coils units. Like a high pitched capacitor whine. Sounds like Eeeeeeeeeeeeeeeee......
https://www.youtube.com/watch?v=ELKDYLReulI
....eeeeeeeeeeE.... and so on and so forth.
The fuel pump only whirrs and clicks for about a second until it primes the injectors then switches off.
The intermittent whirr-click is just the pump topping up pressure in the injectors as the fuel will slowly leak off. Normal.
The last post was made 13 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 96.89 Kb
