How Can I Check Discs Are Straight?
TotalGSXR
PostPosted: 11:47 - 03 Mar 2013    Post subject: How Can I Check Discs Are Straight? Reply with quote
I've a pair of discs which I would like to check are not bent or warped. They are not attached to the bike and all the methods I've read about involve the discs being attached to the bike.
How can I achieve this?
andym
PostPosted: 11:52 - 03 Mar 2013    Post subject: Reply with quote
I checked mine on a worktop with feeler gauges.... not sure if that was good enough or not, but I still put them back on the bike as they were within the limits listed in the book
Ollie1995 This post is not being displayed because the poster is banned. Unhide this post / all posts.
c_dug
PostPosted: 12:29 - 03 Mar 2013    Post subject: Reply with quote
Ideally they need to be on something you can spin them on, I'm assuming they aren't on a wheel? If possible either mount them to a wheel or knock up something they can be spun on.
If that isn't possible then find a flat surface and lay them on it and look across them from level with the disk, any big warping will show as a gap between the disk and surface.
c_dug
PostPosted: 12:35 - 03 Mar 2013    Post subject: Reply with quote
Or I suppose you could coat the disk in something that will leave a print then place it flat on a sheet of paper and check for any points that don't leave a print, these will be raised points and show warping.
Obviously the disks would need a really good clean after.
TotalGSXR
PostPosted: 18:56 - 03 Mar 2013    Post subject: Reply with quote
I've use a ruler to check them and they certainly appear straight, but there is a pulsing through the brake lever, so I'm fairly certain that something's not right with them.
They're not on the wheel due to my wheel being on the bike which I use daily to commute, so it's not that easy for me to swap the discs over. I'm interested with other ideas, if anyone knows any. The bobbins make it impossible to lay flat on a sheet or glass to see any warps. Why did the lazy Susan fade out of vogue?
andym
PostPosted: 19:14 - 03 Mar 2013    Post subject: Reply with quote
If they've already been on the bike but appear to be straight when you are checking them, make sure you clean the area under the disc and tighten all the bolts evenly... I made the same mistake and thought the discs were warped, but turns out it was crap behind the disc that was causing it
WULFSTAN
PostPosted: 19:25 - 03 Mar 2013    Post subject: Reply with quote
If there is pulsing then its fair to say they are warped. Got warped discs on the cbr i don't really worry about them.
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
Ja7
PostPosted: 19:32 - 03 Mar 2013    Post subject: Reply with quote
Until mot time
WULFSTAN
PostPosted: 19:47 - 03 Mar 2013    Post subject: Reply with quote
Ja7 wrote:
Until mot time
What can i say ive got a good mot man.
The last post was made 13 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 64.91 Kb
