bike not running right
kevin-46
PostPosted: 15:18 - 03 Mar 2013    Post subject: bike not running right Reply with quote
Have a zz400 is not running right when i give it throttle in 1st gear or second in bogs and then goes i have
cleaned and balanced carbs
new spark plugs
checked the ignition coil each reading at 7v
the left coil pack i tested with spark plug and it was a light spark and not as fast and as bright as the right coil pack
New battery as well
Any ideas Whats wrong ?
Kevin
bikerestorer
PostPosted: 15:43 - 03 Mar 2013    Post subject: Reply with quote
Is it worse when its hot? if it is it could be running too rich. not much help sorry.
kevin-46
PostPosted: 18:39 - 03 Mar 2013    Post subject: bike Reply with quote
no mate the carbs were set to stock when they where cleaned out
Kevin
iMark
PostPosted: 18:48 - 03 Mar 2013    Post subject: Reply with quote
Pilot Screw "Stock" Settings are baseline.. Doesn't mean it's correct
Apparently mines are supposed to be 1¼ turns out, but that is way too lean.
I actually have mines out 1¾ turns
K8 GSXR 1000
kevin-46
PostPosted: 19:09 - 03 Mar 2013    Post subject: bike Reply with quote
all mine are out 2 1/2 turns [/u]
Kevin
iMark
PostPosted: 19:28 - 03 Mar 2013    Post subject: Reply with quote
Well that's a start Wink
Are they fuel screws or air screws?
(Engine side or air box side of the carburettor)
I'm gonna presume they are fuel screws though, Try turning them in ½ a turn each which should lean it out.
K8 GSXR 1000
kevin-46
PostPosted: 19:35 - 03 Mar 2013    Post subject: Reply with quote
air and fuel screw
Kevin
The last post was made 13 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 49.72 Kb
