Blipping throttle stalls
Kirmit
PostPosted: 11:48 - 18 Nov 2004    Post subject: Blipping throttle stalls Reply with quote
Hi, I have a Honda City Flyer 125. When Idle, either in gear with clutch in or in netrual and I blip the throttle hard the engine stalls. But if I do slowly everything is fine. Any suggestions?
Kirk
mr.z
PostPosted: 13:42 - 18 Nov 2004    Post subject: Re: Blipping throttle stalls Reply with quote
Do eveything slowly? Razz
The city fly is the same (i think) as the cg125 engine/carbs wise.. is it doing this when the engine is fully warmed up? (5 minutes of gentle reving or a 5 mile run out) because if its doing it when cold i wouldn't worry too much, mine did, a mates varadero does and to a degree my 500 twin does as well (a good handfull from cold will stop it ded). If this is happening when the bike is fully warmed up then you might have a fueling issue, but even then it wouldn't supprise me entiely if this was pritty much a standard thing anyways... only stalling issue i had on the cg was rain (getting at the ignition system) and allways at lights Sad
If its not happening at lights e.t.c. dont worry about it too much.
Sory i cannot off more insight but somebody helpfull should be allong shortly though Razz Thumbs Up
PostPosted: 13:58 - 18 Nov 2004    Post subject: Reply with quote
As above, not that unusual but generally because it is set up a touch lean off idle. You might be able to improve it but richening the idle mixture a touch (generally a screw which you undo or do up slightly, probably no more than 1/2 a turn) or by dropping the clip down a notch on the needle jet (so the needle is slightly higher in the carb slide).
Kirmit
PostPosted: 14:49 - 18 Nov 2004    Post subject: Reply with quote
Thanks for the quick response. So far I've only had a problem when I've first got on. Will try again tonight once its warmed up for 5-10 minutes.
Very Happy Very Happy
The last post was made 21 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 41.79 Kb
