thundercat water pump drive
justin2482
PostPosted: 23:07 - 03 Mar 2013    Post subject: thundercat water pump drive Reply with quote
Chain came off my bike took out water pump and clutch rod .there is a drive shaft that sits in the crank case . The clutch drives the oil pump this in turn slots onto the shaft that runs through the engine the water pump slots onto the other end .i think ive bent that shaft does anybody know how to remove it
Paddy Blake
PostPosted: 23:30 - 03 Mar 2013    Post subject: Reply with quote
Hi.
You might have a problem if the shaft is bent.
Drain the oil and then remove the clutch.
Turn the oil pump driven gear to align the holes in the gear with the pump mounting bolts.
Unscrew the bolts and withdraw the pump from the engine,being prepared to catch any residue oil.
Discard the gasket as a new one must be used.
Remove the dowel from either the pump housing or the crankcase if it is loose.
Paddy Blake
PostPosted: 23:54 - 03 Mar 2013    Post subject: Reply with quote
Here is a picture.
https://omg.wthax.org/IMG_0248_1.jpg
The last post was made 13 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 34.88 Kb
