Two folders with the same name in the same folder.
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
Ariel Badger
PostPosted: 22:55 - 05 Mar 2013    Post subject: Two folders with the same name in the same folder. Reply with quote
I did not think it possible...
oldpink
PostPosted: 23:00 - 05 Mar 2013    Post subject: Reply with quote
with windows anything is possible Laughing
KDub
PostPosted: 23:15 - 05 Mar 2013    Post subject: Reply with quote
Slightly unrelated but you cannot make a folder named "CON" anywhere: https://www.hoax-slayer.com/con-folder-name.shtml
Edit: This is definitely true for XP, I'm not sure about other Microsoft OS's.
Redoko
PostPosted: 00:07 - 06 Mar 2013    Post subject: Reply with quote
Confirmed. Does not work on 7.
Huh, how interesting.
Irn-Bru
PostPosted: 00:18 - 06 Mar 2013    Post subject: Reply with quote
https://i.imgur.com/n8EZW6V.png
Razz
oldpink
PostPosted: 01:12 - 06 Mar 2013    Post subject: Reply with quote
there are certain restricted codes in windows that won't allow certain file / folder names as they are reserved code words
there is also some coder "Jinks" in windows so if you do certain things you get unexpected results
PostPosted: 13:46 - 06 Mar 2013    Post subject: Reply with quote
Does one of them have a space after the name?
Islander
PostPosted: 14:22 - 06 Mar 2013    Post subject: Reply with quote
CON is the device name for console. People who remember DOS and batch files might well remember the command 'copy con' - the editor for people that could type confidently and accurately. Razz
It's still there in Windows 7. Shocked
LordShaftesbu...
PostPosted: 15:05 - 06 Mar 2013    Post subject: Re: Two folders with the same name in the same folder. Reply with quote
I noticed this quite recently too, the wonders of Win 7 (doesn't work in any other version I've tried, don't know about Vista though).
panrider_uk
PostPosted: 15:40 - 06 Mar 2013    Post subject: Reply with quote
I still use that on occasion for whipping up a quick batch file.
Mark
Ariel Badger
PostPosted: 19:21 - 06 Mar 2013    Post subject: Reply with quote
I took that to our IT Techs today and they are not at all happy. It was like a child finding out that the Tooth Fairy is not real, their belief system had been challenged and they did not know what to do.
Irn-Bru
PostPosted: 20:25 - 06 Mar 2013    Post subject: Reply with quote
Like Chris said one will have a space after the name, the old alt+0160 trick.
PostPosted: 21:57 - 06 Mar 2013    Post subject: Reply with quote
Easy way to see if it's a space after the name is to highlight both together:
Ariel Badger
PostPosted: 22:27 - 06 Mar 2013    Post subject: Reply with quote
I did that last night Pete. No space.
Ariel Badger
PostPosted: 23:00 - 06 Mar 2013    Post subject: Reply with quote
Ok this just got weirder.... I was trying to take a shot of it with both highlighted but I managed to drop the one into the folder above. I then tried to drop it back to where it came from but Windows will not let me as there already is a folder called S******* there!
PostPosted: 23:05 - 06 Mar 2013    Post subject: Reply with quote
Problem solved!
I would now run disk check. Right-click that drive in My Computer - properties - tools - check now.
Ariel Badger
PostPosted: 23:21 - 06 Mar 2013    Post subject: Reply with quote
I tried System Restore but it would not put it back Sad
PostPosted: 23:58 - 06 Mar 2013    Post subject: Reply with quote
Do the alt+0160 thing then it will go back. IT can pat themselves on the back for fixing it then. Either that or it will properly weird them out Very Happy
chrisw
PostPosted: 00:01 - 07 Mar 2013    Post subject: Reply with quote
There really are only a few options.
Unprintable characters in the folder name
Corrupt file system
Juntions/Symlinks hiding the real path
Two folders/files with truly identical names cannot exist next to each other in a healthy filesystem.
J.M.
PostPosted: 10:46 - 07 Mar 2013    Post subject: Reply with quote
What folder is it in?
A quick read up suggests that if you had something like C:\Users\<myUserId>\Documents\Symantic and C:\Users\Public\Documents\Symantics and you were using the Library view, both folders would appear under the same name. They are both at different locations, however.
If they both truly are at the same location with the same name... move the contents from one in to the other and then delete the empty folder. Job jobbed!
2004 R1 & 2018 XSR900
Spudly
PostPosted: 11:07 - 07 Mar 2013    Post subject: Reply with quote
I haven't tried this yet, but the only thing I can think of is that the folders may have been created with very slightly different attributes.
Even still though, I'm glad I don't have to write it up, that would drive me insane.
The Old Apprentice
Alpha-9
PostPosted: 11:11 - 07 Mar 2013    Post subject: Reply with quote
There was an easter egg about typing something into notepad then opening it again and the text changes, was creepy
Fzr-600 1999
hellkat
PostPosted: 11:12 - 07 Mar 2013    Post subject: Reply with quote
Mark
I still very occasionally use it to see what's in various directories (even if I have no idea what it is
"cd .." is still one of the fastest key combinations in my repertoire Laughing
Alpha-9
PostPosted: 11:17 - 07 Mar 2013    Post subject: Reply with quote
I used to love making batch files, I made one that selfduplicated itself with random file names, if you ran it it would crash your PC guaranteed
I was gonna put it in startup on someones PC Laughing
Fzr-600 1999
andym
PostPosted: 12:50 - 07 Mar 2013    Post subject: Reply with quote
When I first seen this thread my first thought was some kind of virus causing the duplicate folder names.... not as sure now.
Anyway, what was that about not being able to give folders certain names?
https://img.photobucket.com/albums/v320/andy36586/folder-names_zps31fb9840.jpg
You can use any folder name you want through the dos prompt:
md .\folder name\
The last post was made 13 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.62 - MySQL Queries: 13 - Page Size: 129.88 Kb
