peugeot xps 50 oil leak
ashleyhobson
PostPosted: 21:34 - 07 Mar 2013    Post subject: peugeot xps 50 oil leak Reply with quote
I NEED SOME HELP ON MY PEUGEOT XPS 50 LEAKING OIL FROM MY CLUTCH ARM/ ACTUATOR IT HAS THE AM6 ENGINE I HAVE CHANGED THE OIL SEAL AND CLUTCH ARM AND IT IS STILL LEAKING OIL SHOULD THE CLUTCH ARM JUST PULL OUT OR SHOULD IT CLICK IN ALSO MY OIL LEVEL IS PERFECT AND MY OIL HAS PRESSURE IS THAT RIGHT
HI MY NAME IS ASHLEY I NEED SOME HELP ON MY PEUGEOT XPS 50 LEAKING OIL FROM MY CLUTCH ARM/ ACTUATOR IT HAS THE AM6 ENGINE I HAVE CHANGED THE OIL SEAL AND CLUTCH ARM AND IT IS STILL LEAKING OIL SHOULD THE CLUTCH ARM JUST PULL OUT OR SHOULD IT CLICK IN ALSO MY OIL LEVEL IS PERFECT AND MY OIL HAS PRESSURE IS THAT RIGHT
Ollie1995 This post is not being displayed because the poster is banned. Unhide this post / all posts.
mumbles
PostPosted: 21:46 - 07 Mar 2013    Post subject: Re: peugeot xps 50 oil leak Reply with quote
I might be deaf but I can read just fine thankyou Wink
Anyway, re-post you question hear https://www.apriliaforum.com/forums/forumdisplay.php?21-RS50-Technical they know every detail about the am6 and I have seen a thread not too long ago with the same problem if you want I will dig it up ?
Warming the world 2 strokes at a time.
2008 rs50 (SOLD) - 2006 gz125 - (Winter Bike) - 1981 CB250N (In Restoration)
ashleyhobson
PostPosted: 21:46 - 07 Mar 2013    Post subject: Reply with quote
help fast
ashleyhobson
PostPosted: 21:48 - 07 Mar 2013    Post subject: Reply with quote
yes please thankyou
suzukirider19...
PostPosted: 21:51 - 07 Mar 2013    Post subject: Reply with quote
im pretty sure they have a retaining bolt on them. when i had my senda never had any leaks
husky sm610
mumbles
PostPosted: 21:56 - 07 Mar 2013    Post subject: Reply with quote
https://www.apriliaforum.com/forums/showthread.php?256927-Clutch-fulid-leak&highlight=clutch+arm
according to this you might be missing the 'shim'
here's some more
https://www.apriliaforum.com/forums/showthread.php?178151-Clutch-lever-leak!!&highlight=clutch+arm
https://www.apriliaforum.com/forums/showthread.php?259384-oil-leak&highlight=clutch+arm
ashleyhobson
PostPosted: 21:58 - 07 Mar 2013    Post subject: Reply with quote
where does the retaining bolt position i know t have a spring on the arm isthat insted of a bolt
The last post was made 13 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.69 - MySQL Queries: 13 - Page Size: 57.49 Kb
