bent bar end?
bike-stan13
PostPosted: 21:45 - 07 Mar 2013    Post subject: bent bar end? Reply with quote
Had a little bit of a low side the other night and in addition to other damage, the right hand bar end bent quite badly and is stopping the throttle from shutting by itself.
If I try and take the bolt out with an allen key the bar end just turns in the handlebar.
Any ideas for how I can get it out?
soforene This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
haroman666
PostPosted: 22:53 - 07 Mar 2013    Post subject: Reply with quote
Sounds like a brute force jobby. If it's fucked then you may aswell take it off.
If you can try bending it back, if not, stop...
Hammer time.
Bezzer
PostPosted: 23:06 - 07 Mar 2013    Post subject: Reply with quote
You're probably looking at a happy 15-20 minutes with a hacksaw Confused saw through the bar end below the bolt head so you can slide off the weight, be able to get better access to the innards and also check if the throttle tube now returns or if it's mangled/ bent as well.
bike-stan13
PostPosted: 23:16 - 07 Mar 2013    Post subject: Reply with quote
Thanks for the tips guys.
Just to clarify, the throttle isn't returning because the bar end is bent at such an angle that part of it is bent into the end of the rubber grip thus stopping it from moving freely.
The last post was made 13 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 42.48 Kb
