Chain rivet tool & tight spots
Ripp3rCrust
PostPosted: 11:06 - 08 Mar 2013    Post subject: Chain rivet tool & tight spots Reply with quote
Hi,
When cleaning my chain I noticed that there is a slight tight spot between two of the links. Other than this, it is in relatively good condition so I am a little reluctant to replace the chain and sprockets, in addition to being poor at the minute!
As a result of this I am going to attempt to remove the chain and soak it overnight in engine oil, as I read somewhere that this may help. Can anybody confirm that this is the correct method? If not any other suggestions would be greatly appreciated.
For this job I think that I need a chain riveting tool, however, I have checked Halfrauds online and can only see bicycle tools on there. Does anybody know any of the chain shops or any independant shop in the Sheffield area that may have them?
Thanks
Current: '05 CBR600F - Previous: '01 GSF600S Bandit, '06 XR125
Islander
PostPosted: 11:30 - 08 Mar 2013    Post subject: Reply with quote
It's probably not necessary to remove the chain. Try giving the tight links a good soak with paraffin or diesel followed by a good scrub to clean the crap out of them, then soak the link with some EP90 gear oil (or engine oil if you don't have that) leave it on overnight and then wipe the excess off.
You'll probably find that now you've given the chain a decent clean and lube, they'll loosen in normal use anyway. I'd only worry if they were tight to the point of being seized.
mudcow007
PostPosted: 11:58 - 08 Mar 2013    Post subject: Reply with quote
on a pedal bike (im guessing its the same on a proper bike) when you rivet the chain back together you get stiff links
if you put a screw driver gentle between the two plates an gently open them a tiny bit
that normally resolves it
Ripp3rCrust
PostPosted: 12:53 - 08 Mar 2013    Post subject: Reply with quote
Thanks for the suggestions, I shall pick some paraffin up tonight and give it a try, if not I will attempt the screwdriver method.
Hopefully won't have to invest in a chain riveter just yet!
Suntan Sid
PostPosted: 13:41 - 08 Mar 2013    Post subject: Reply with quote
There is no need to split the chain.
Loosen the chain adjusters and get the chain off the rear sprocket.
Remove the rear wheel.
Half of your chain can now be soaked in a bath of oil for a few hours, move the chain round to give the other half its own oil bath.
No chain splitter required!
Ripp3rCrust
PostPosted: 14:30 - 08 Mar 2013    Post subject: Reply with quote
May have to try this if the other methods fail.
This may be a silly question but why would I have to remove the rear wheel after I have gotten the chain off? Is it for putting it back on?
Thanks.
Islander
PostPosted: 14:38 - 08 Mar 2013    Post subject: Reply with quote
Because in order to drop the chain, you'll need to get it past the spindle. Smile
Ripp3rCrust
PostPosted: 14:56 - 08 Mar 2013    Post subject: Reply with quote
Ah, of course! I had a feeling it may have been a silly question! Laughing
andym
PostPosted: 16:13 - 08 Mar 2013    Post subject: Reply with quote
I might just be lazy here, but I wouldn't even bother with removing the wheel...
If it's only the one part that feels a bit tight then at most I would slacken the chain a bit, give it a good scrub with white spirit, move the links up and down and if there is any improvement then I would give it a little splash of oil and continue until it felt as loose as the rest of the links... then tighten up the chain again
The last post was made 13 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 60.61 Kb
