Drive chain care
Spud_Gunn
PostPosted: 20:29 - 17 Nov 2004    Post subject: Drive chain care Reply with quote
Could you guys offer a little advice on chain care?
I bought an XR125 a week ago, this is going to be a daily rider all through the winter so need some advice on how to look after the chain.
I have ordered some Castrol chain wax, but I am unsure on how to clean it. I am guessing that WD40 is good to clean with (unlimited supply, used to work in an aerosol factory). Guess I just need confirmation as I have never owned a bike before, and I don't know anyone else who has one either.
jay12329
Dr. Evil
PostPosted: 22:17 - 17 Nov 2004    Post subject: Reply with quote
WD-40 + chain = Big no no. it kills the o-rings.
I use holts motor cycle de-greaser and castrol chain wax. Removed everything with the de-greaser then relubed every 2-300 miles.
HTH
J
PostPosted: 23:18 - 17 Nov 2004    Post subject: Reply with quote
WD40 is not a good idea on O ring or X ring chains, but fine on normal chains.
To clean them I would use a light oil, but generally would not bother. Just keep it well lubed.
Guest
PostPosted: 23:21 - 17 Nov 2004    Post subject: Reply with quote
Clean the chain and sprockets with paraffin and a stiff brush, then mop it dry with an old towel.
I liked chain greases rather than aerosols myself (scotty now) - I warmed the tin on the stove till it's a bit runny then paint it on with another brush.
bklynvx1
PostPosted: 23:38 - 17 Nov 2004    Post subject: Reply with quote
do you have to remove the chain or anything or have the back tire up when cleaning and lubing the chain?
Guest
PostPosted: 23:55 - 17 Nov 2004    Post subject: Reply with quote
It's easier if you have a centre-stand so the back wheel's off the ground, then you can spin it by hand while you're cleaning/oiling it - no real need to remove the chain to do it.
Don't be tempted to do it with the engine running and the bike in gear unless you're not bothered about losing a finger or two Sick
PostPosted: 22:54 - 18 Nov 2004    Post subject: Reply with quote
Would an XR125 have an o-ring chain anyway or just a standard heavy duty chain?
I can think of no reason why a learner legal bike needs an o-ring chain. A well oiled heavy duty chain should be fine. I always used to clean my HD chains in paraffin then oil them with EP90 gear oil. In the summer I used to clart them in graphite grease but it turns into grinding paste in no-time during the winter (as does wax based chain lube in my experience).
The last post was made 21 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 52.21 Kb
