| c_dug |
 c_dug Super Spammer
 Posted: 18:24 - 02 Mar 2013 Post subject: D.I.Y lean-o-meter, 1.0 |
I had a quiet day at work today so I used a few bits of scrap material from my bench and knocked up a Lean-o-meter, it probably won't get used much, or be that accurate, I just did it because I can
First thing I did was print off a protractor and find a suitable piece of plastic, in hindsight the piece I chose was a little too flexible, leading to some bending when tightening the nuts and bolts. Next I scored the plastic with a compass and then cut it out and neatened it up:
https://i235.photobucket.com/albums/ee81/paddy2007dug/WP_000139_zpscfc8d9ff.jpg
Next I considered the best way to make the pointer, after digging through my draw I came across one of these:
https://i235.photobucket.com/albums/ee81/paddy2007dug/WP_000140_zps4a331e3b.jpg
The bar and eye seemed perfect, but the threaded part wasn't long enough, I've known the theory of using a die for a while but never put it into practice, so this was a good a time as any to learn:
https://i235.photobucket.com/albums/ee81/paddy2007dug/WP_000142_zps7d9cf82e.jpg
Next I fount a perfect piece of thin aluminium for the pointer, it was a fraction too big for the eye so I filed it down by a small amount. This picture also shows the new thread on the bolt. The following picture shows the original bolt for comparison.
https://i235.photobucket.com/albums/ee81/paddy2007dug/WP_000143_zps5fce83d8.jpg
https://i235.photobucket.com/albums/ee81/paddy2007dug/WP_0001411_zps8ed5441d.jpg
Next I started thinking about the ballast, I found an off-cut of aluminium diamond plate which I thought may do the trick, I cut the plate in two as it was a little over size for the job:
https://i235.photobucket.com/albums/ee81/paddy2007dug/WP_000144_zpsd8778e7e.jpg
Next I drew up a template for the measurements based on the protractor:
https://i235.photobucket.com/albums/ee81/paddy2007dug/WP_000146_zps41be58cd.jpg
Then I marked up the plastic with a sharpie, drilled a hole in the ballast and bolted it all together:
https://i235.photobucket.com/albums/ee81/paddy2007dug/WP_000147_zps4b888ed5.jpg
https://i235.photobucket.com/albums/ee81/paddy2007dug/WP_000148_zpsef2336ae.jpg
Lastly I added a stand so it could be mounted to the bike:
https://i235.photobucket.com/albums/ee81/paddy2007dug/WP_000155_zpsae374490.jpg
https://i235.photobucket.com/albums/ee81/paddy2007dug/WP_000156_zps26301bad.jpg
Added a spirit level, just because:
https://i235.photobucket.com/albums/ee81/paddy2007dug/WP_000157_zps490273a2.jpg
And mounted it to the bike:
https://i235.photobucket.com/albums/ee81/paddy2007dug/WP_000158_zps90f85aaf.jpg
It was tested on the way home, it didn't move much so I think the ballast needs rethinking, and possibly the method of mounting the pointer too. Mark 1.1 will follow when I have another quiet day.
Please feel free to add suggestions. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 18:29 - 02 Mar 2013 Post subject: |
I wouldn't expect it to move much regardless of how much ballast you have - any lean would be counteracted by centrifugal (centripetal? Can never remember) force. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| Pete. |
 Pete. Super Spammer
| c_dug |
 c_dug Super Spammer
| Pete. |
 Pete. Super Spammer
| c_dug |
 c_dug Super Spammer
| c_dug |
 c_dug Super Spammer
| -Savage- |
 -Savage- World Chat Champion
| fatpies |
 fatpies World Chat Champion
| kestrel |
 kestrel Nearly there...
 Posted: 19:45 - 02 Mar 2013 Post subject: |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 13:32 - 04 Mar 2013 Post subject: |
| P.addy |
 P.addy Red Rocket
 Posted: 13:38 - 04 Mar 2013 Post subject: |
Download Diablo Super Biker app  |
| c_dug |
 c_dug Super Spammer
| DrDonnyBrago |
| c_dug |
 c_dug Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 14:24 - 04 Mar 2013 Post subject: |
It'll work great if you can lean whilst going straight  ____________________ a.k.a 'Geri'
| Nexus Icon |
 Nexus Icon World Chat Champion
 Posted: 14:45 - 04 Mar 2013 Post subject: |
Buy this, step up your voltage to 28V and Bob's your uncle. ____________________ Greetings from Shitsville! |
| c_dug |
 c_dug Super Spammer
 Posted: 18:44 - 06 Mar 2013 Post subject: |
Made a start on it today. Windex does not work as the fluid Machining coolant seemed much better and there is a barrel of used stuff sitting in the workshop so that shall be the fluid of choice.
I think this one may actually work  ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| The Artist |
 The Artist Super Spammer
 Posted: 18:48 - 06 Mar 2013 Post subject: |
You need a gyro or something to reference the ground. You can't use ballast in this application. |
| c_dug |
 c_dug Super Spammer
| The Artist |
| c_dug |
 c_dug Super Spammer
| N cee thirty |
 N cee thirty Banned
| c_dug |
 c_dug Super Spammer
| Popee1985 |
 Popee1985 Derestricted Danger
The last post was made 13 years, 220 days ago. Instead of replying here, would creating a new thread be more useful? |
