Will these fit?
Sid_The_Sloth
PostPosted: 02:30 - 09 Mar 2013    Post subject: Will these fit? Reply with quote
I've got a 96 Bandit, GSF600 V I'm sure. Went to replace the front pads only to find the retaining pins flat head screw driver bit is pretty much done. So need to buy new 1s. But unsure if these will fit? https://www.ebay.co.uk/itm/Suzuki-GSF-600-U-Bandit-V-GN77B-1997-Front-Brake-Pad-Pin-/140845199046
PostPosted: 10:46 - 09 Mar 2013    Post subject: Reply with quote
What does the VIN plate state the vehicle number to be? Same side as the throttle attached to frame.
Pretty sure they were unchanged on the MK1 Bandits so is probably fine!
Copycat73
PostPosted: 11:52 - 09 Mar 2013    Post subject: Reply with quote
are you sure its the pin that is shagged .. cos would the pin not need an allen key to remove it..think wots knacked is the grub screw cover..
there is one in the picture you posted up
caveat emptor
mysterious_rider
PostPosted: 12:06 - 09 Mar 2013    Post subject: Reply with quote
Yeah if it's almost flush with the surface, it's just the allen key cover. Just drill it, the pin allen key sits quite a bit further inside.
KAWASAKIIIII
Sid_The_Sloth
PostPosted: 01:26 - 10 Mar 2013    Post subject: Reply with quote
Ahhh right OK I didn't realise the fault head screw bit I could see was just a cover, I feel more confident putting more effort trying to take them out then.
The last post was made 13 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 42.06 Kb
