| toppetsaha |
 toppetsaha Two Stroke Sniffer
| Copycat73 |
 Copycat73 World Chat Champion
| toppetsaha |
| suzukirider19... |
 suzukirider19... Nova Slayer
| numpty2 |
 numpty2 Trackday Trickster
| toppetsaha |
| numpty2 |
| toppetsaha |
| Howling TerrorOutOfOffice |
 Posted: 22:08 - 09 Mar 2013 Post subject: |
Just a thought.
Might be worth checking the choke mechanism is working. Reason being, I had the choke on my 250 working its way from the off position to the half-choke position. It's the plunger type. Took me a minute to suss what had happened. Similar results to what you are experiencing. ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| toppetsaha |
 Posted: 22:17 - 09 Mar 2013 Post subject: |
Brilliant, will look at that tomorrow.
I have already taken the air filter out and hoovered it..... a couple of times now
It got a bit dark today by the time i got round to checking the plugs, they looked fairly new but i will take them out tomorrow,clean them & check the sparks. |
| toppetsaha |
| numpty2 |
 Posted: 22:40 - 09 Mar 2013 Post subject: |
The choke cables on these can cause problems. Cable routing is a bit tight and some people have issues with the engine cutting out on full steering lock (when this pulls the choke cable and the choke goes on).
Check that the choke outer sleeve is properly seated at the carb.
But I'd check the fuel filter first, it is easy & quick to do.
If you do decide to strip the carb down, this might help:
https://www.youtube.com/watch?v=RIa23_0Hn9I
But this will be the USA version, and the UK one has some differences, perhaps just the jet sizes. |
| toppetsaha |
 Posted: 22:49 - 09 Mar 2013 Post subject: |
| numpty2 wrote: | The choke cables on these can cause problems. Cable routing is a bit tight and some people have issues with the engine cutting out on full steering lock (when this pulls the choke cable and the choke goes on).
Im not too sure about stripping the carb, the ratio screw settings confuse me a little, plus i wouldnt want to create more problems than i already have.
Cheers for the vid anyway, i ll that to my CB collection  |
| numpty2 |
| toppetsaha |
 Posted: 23:30 - 09 Mar 2013 Post subject: |
i did give it a go before on a moped... didnt go very well...
I have considered the carburetor cleaner, will check the free options first tho
That sea foam stuff looks like a mix between fuel conditioner and 2 stroke! trust the yanks... |
The last post was made 13 years, 34 days ago. Instead of replying here, would creating a new thread be more useful? |
