 bklynvx1 Derestricted Danger
 Full Bananas Renault 5 Driver
 Posted: 14:28 - 19 Nov 2004 Post subject: |
Full service could include many things.
At a guess on a YZF:-
Change oil and filter (4000 miles I think)
Change spark plugs (every couple of oil changes)
Adjust valves (once in a blue moon, ~20000 miles on the 5 valve Yamaha engines)
Change fuel filter
Change air filter
Check / adjust / lube Steering head bearings.
Check / replace brake pads
Check / lube suspension linkages
Check bulbs
Replace brake / clutch fluid
General check and lube of moving items (brake lever pivots, cables, etc)
Adjust chain
Balance carbs
Change fork oil
Check battery
Could probably think of a few more things. Many of those items would not be required for a minor service, other might need doing differently (eg, clean the air filter rather than replace it).
Note that shimming the valves on a 5 valve Yamaha engine is a time consuming job as the cams have to be removed to change the shims. Fortunatly they do not need doing very often.
 BLOFLY 636 Brolly Dolly
