alternator testing
andym
PostPosted: 19:56 - 09 Mar 2013    Post subject: alternator testing Reply with quote
I've got 2 alternators, 1 is grinding slightly inside (probably because it was stored in a dry shed for almost a year I guess Rolling Eyes ), and 1 has a cracked case. From what I remember I had to charge the battery manually for the zxr (but it could be that it never ran long enough to give a good charge).
So both are off the bike, no way of spinning them fast enough to make them work as they should, so with the aid of a multi-meter, is there a way I can test that at least 1 will charge the battery?
Islander
PostPosted: 21:52 - 09 Mar 2013    Post subject: Reply with quote
The only thing you're going to be able to test is the resistance of the windings. You'll need some numbers to test against too.
The last post was made 13 years, 35 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 31.26 Kb
