Steering head bearing play
Jim Mc
PostPosted: 21:55 - 09 Mar 2013    Post subject: Steering head bearing play Reply with quote
I just got an MOT advisory of free play on the steering bearings and I've been feeling like when I'm tipping the bike in on a corner it 'drops and locks' is the only way I can describe the way that the bike corners, it doesn't feel right. Unsure if this is a symptom of the bearing or maybe the greasy roads.
Everything feels tight enough though from what I can tell, so can anyone recommend a technique to check for free play on the head bearing? How do they test it in the MOT? Fairly sure I'm going to strip it down and replace.
thomp1983
PostPosted: 22:02 - 09 Mar 2013    Post subject: Reply with quote
for mot it's front wheel off ground and rock the forks and feel for play, if it just loose play then you may find tightening the top nut will fix the issue, if it's a notchy feel issue then replacement is the way to go
chris
Raffles
PostPosted: 23:24 - 09 Mar 2013    Post subject: Re: Steering head bearing play Reply with quote
Did you experience these feelings before you got the advisory?
Jim Mc
PostPosted: 00:33 - 10 Mar 2013    Post subject: Reply with quote
I felt this before the MOT but I low-sided about 18 months ago and it hasn't felt right since, maybe it's just psychological. I do get a bit of a squeak when I'm maneuvering the bike on the driveway and turning the steering through full lock, could just be cables rubbing though. The suspension looks fine, there's no twist and the wheel bearings are good. I'll check the steering again in the morning. Thank you.
I actually trust the garage so I'm inclined to think there is a problem.
The last post was made 13 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 38.77 Kb
