Bolt 1, Me 0
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4  Next
Paris2
PostPosted: 13:54 - 10 Mar 2013    Post subject: Bolt 1, Me 0 Reply with quote
My sump plug has rounded off, the damn thing is made of cheese.
https://i138.photobucket.com/albums/q276/parsalanpark/image-6.jpg
As you can see from the picture I have pretty much tried everything Laughing
My only other options as far as I can see are to file it down and fit a 12/13mm socket on (though I think they will round off also) or take it up a garage and get them to weld a new bolt onto it to un do it that way.
Does anyone else have any ideas or success stories. I close to thinking that I should punish the bike by making it use the same oil forever!
Current Ride: Daytona 600
Bezzer
PostPosted: 14:02 - 10 Mar 2013    Post subject: Reply with quote
You want something like these https://www.machinemart.co.uk/shop/product/details/5-piece-bolt-grip-set-expansion-set?da=1&TC=SRC-irwin+bolt
Mate's got a full set I've used a few times and they do work. Probably more cost effective for a one off job to take it to a garage to get them to do it, they will no doubt have similar ones......but then again you can never have enough tools Mr. Green
fatpies
PostPosted: 14:07 - 10 Mar 2013    Post subject: Reply with quote
Maybe replace the sump if it is a separate piece?*
*and then round off all the bolts which hold the sump in place and require a new gasket
bridgedino
PostPosted: 14:14 - 10 Mar 2013    Post subject: Reply with quote
These things I hate.
Why do the big bike names build bikes, then find one of the most exposed parts of the bike ( guaranteed to get every ounce of road muck on it ) on the underside. Then fit a bolt that's sure gonna rust as long a there's oxygen on the planet
These things I hate
thomp1983
PostPosted: 14:33 - 10 Mar 2013    Post subject: Reply with quote
options are either, hammer a smaller socket on, irwin grip or weld a bar or bolt to it and use that to undo it
chris
Im-a-Ridah
If a bolt feels like it's going to round off, I take to it with a blowtorch and heat it up, then WD40 it, hit it with a hammer a few times then leave it a while. Then come back, heat it up again, and it usually undoes Thumbs Up
Also, make sure you use a decent spanner which grips the whole bolt/nut, not just the corners. Even spanners as cheap as these will do the job
https://direct.asda.com/Draper-DIY-Metric-Combination-Spanner-Set/001235602,default,pd.html
numpty2
PostPosted: 14:41 - 10 Mar 2013    Post subject: Reply with quote
I doubt mole grips would work, but worth a try.
I have had results with the self tightening wrench type things such as:
https://www.amazon.co.uk/Laser-2463-Speed-Wrench-150mm/dp/B003AMZ0QO/ref=sr_1_2?ie=UTF8&qid=1362926108&sr=8-2
You can get 6" & 8" versions. Ebay has them as well, but for the same price I'd go with Amazon since the suppliers are a bit more trustworthy. It's the kind of tool you will use once every 10 years, but you can never have too many tools.
I reckon this will shift it, but make very sure you are turning the right way. It is very easy to make a mistake when working upside down.
J4mes
PostPosted: 14:46 - 10 Mar 2013    Post subject: Reply with quote
If you're stuck as it's Sunday afternoon and you can't get anywhere you could always try filing some new flats on to it and then as mentioned above, hammer a smaller socket on.
I would also try the mole grips, as tight as possible and then whack with a hammer.
I'd also make sure you have a decent 6 sided socket for next time, if that isn't what you used today.
frostage
PostPosted: 14:49 - 10 Mar 2013    Post subject: Reply with quote
This. Heat the bolt head, let it cool, apply WD40, wait, repeat. after 5 times get a set of mole grips on it and if it still doesnt budge try filing a few straights into it and get an impact driver on there.
2000 Gixxer 750
1995 RM 250
Paris2
PostPosted: 15:11 - 10 Mar 2013    Post subject: Reply with quote
Thanks for the tips so far.
I don't however have access to a blow torch, so that's a no go.
I have been using a halfords pro socket set, so pretty decent tools. The bolt was slightly rounded when I started and the sockets/spanners seem to have just made it worse.
I think I will try to file the edges first, though I think a smaller socket will do the same.
Oh and I've tried mole grips, and they rounded the shit off it Laughing
Musketeer
PostPosted: 15:13 - 10 Mar 2013    Post subject: Reply with quote
If it's rounded off then replace it. My favourite tool for rounded off bolts is this...
https://i244.photobucket.com/albums/gg19/Mordoklej/Random/pipewrench.jpg
It will chew into the bolt no matter how f00ked it is.
numpty2
PostPosted: 15:22 - 10 Mar 2013    Post subject: Reply with quote
Yes the Stilson plumber's wrenches are very good, but I think they might a bit too bulky for this. They are a bit sloppy and it depends on how much of the bolt head is exposed. Maybe a small wrench plus a piece of pipe to extend it.
Stonefly
PostPosted: 15:23 - 10 Mar 2013    Post subject: Reply with quote
I really wouldnt do that. There is a risk of cracking the alloy sump pan. I did this once myself, years ago and errrrrrrrr cracked the sump pan.
Current......Kawasaki ZZR1200 C2H and Kawasaki ZZR600 E7
Previous....Yamaha FS1E, Honda SS50, Suzuki AP50, BSA Bantam D14, Honda CD175, Honda CB250N, Kawasaki Z250A3, Yamaha RD250E, Kawasaki Z400, Kawasaki Z500, Kawasaki GPz550, Honda NTV600, Kawasaki GT750, Kawasaki Z1000R, Kawasaki GPX250
andym
PostPosted: 15:24 - 10 Mar 2013    Post subject: Reply with quote
+1 for the mole grips... I've never come across a nut or bolt that give up its fight when using them.
Only a pisser when you haven't got enough space to get them in there, so have to resort to something else.... usually bashing it's brains in with a hammer in my case
Paris2
PostPosted: 15:36 - 10 Mar 2013    Post subject: Reply with quote
Right I'm going back out there to try the mole grips again, they are almost brand new so are up to the job. Ill get ready to do some grunting and try not to pull the bike off the stand. Laughing
I already have a spare to replace it, obviously, as I have fucked this bolt up so bad. Ill get a better picture of just how much when I get it off.
Musketeer
PostPosted: 15:43 - 10 Mar 2013    Post subject: Reply with quote
Also.. Make sure you turn in the right direction.. Just saying Wink
Islander
PostPosted: 15:59 - 10 Mar 2013    Post subject: Reply with quote
Also....
WD40? C'mon guys you should know better than that. Plus Gas or another type of penetrating oil.
Stilsons might shift it if there's room to get them on properly. +1 for making sure you're turning it the right way too. Laughing
numpty2
PostPosted: 16:09 - 10 Mar 2013    Post subject: Reply with quote
I wonder how many of us have actually done the wrong way thing? I can proudly say that I've never done it with a sump plug, but as for other bolts... It's always the upside down / back to front work that leads to errors. I find it safer to let my hands do the thinking in these situations, since my brain can get it all wrong.
Boris the spider
PostPosted: 16:17 - 10 Mar 2013    Post subject: Reply with quote
As a coachbuilder , i have fucked up on so many occasions.
Crying or Very sad
One of the best items ever kept in my toolbox if a good pair of molegrips.
Applied properly as others have stated. They will move most things.
Or snap them. Laughing
Yes I'm a pig....And yes... The working public do pay my wages. Tho I contribute to your benefits you lazy c##t. You do not pay my wages. So go fcuk yourself.
The Artist
PostPosted: 16:25 - 10 Mar 2013    Post subject: Reply with quote
Last resort is welding another nut on top.
The last post was made 12 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 131.19 Kb
