| GSTEEL32 |
 GSTEEL32 Traffic Copper
| Jayy |
 Jayy Mr. Ponzi
 Posted: 21:36 - 10 Mar 2013 Post subject: |
I will suggest a slight alternative on the cyclone system but made by the same people.
You can probably get this down to £22 odd if you shop around but it's a cycle micro 2+ device.
https://www.ebuyer.com/274064-cyclone-micro-2-mkv-player-cyclone-micro-2-player
Couple that with an external 1TB HDD (plugs in via USB) and you have a very capable player. I have one of these, recommended them to my parents and sister and not had a single issue.
I know it's not all contained in one unit (have to plug HDD in) but it really is simple. Box goes in to TV via HDMI and HDD in to box via USB.
The only cons with the cyclone series is:-
Controller is a bit flimsy and sometimes have to point it directly at the box head on or it doesn't register what you're clicking.
If you have hundreds of files in one folder, there's no search. You have to scroll down to find your stuff.
Other than that, can't fault them. I would never recommend DVD/Bluray players to anyone when you can store hundreds of your films on 1 drive. |
| Dweezil |
 Dweezil L Plate Warrior
 Posted: 21:54 - 10 Mar 2013 Post subject: |
| ZX Jay wrote: | I will suggest a slight alternative on the cyclone system but made by the same people.
I use an old style Xbox (soft modded) networked to my comps through a linux server running samba (windows to linux transfer protocol) linked to a hub so all PC's on the network are seen by all others including the xbox. plays anything I throw at it using Xbox media centre (XBMC) If you have an old Xbox, all you need is another network card in your comp and it should read it fine. it will cost you about £5.00 for the card and a cat 5 cable.
Hope this helps mate |
| Jayy |
 Jayy Mr. Ponzi
 Posted: 22:00 - 10 Mar 2013 Post subject: |
That's a bit complex for his missus though mate, needs to be easy to setup  |
| Dweezil |
The last post was made 13 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
