2008 YBR 125 not starting
tom_m
PostPosted: 21:41 - 12 Mar 2013    Post subject: 2008 YBR 125 not starting Reply with quote
Just popped round to have a look at brothers ybr, it is a 2008 EFI model. when you try to start it the engine management light (orange)flashes repeatedly, does have a spark but just wont fire up, tried different plug, tried to bump it and kick it over without any luck.
anybody any ideas? Thumbs Up Karma
Current: 2005 Kawasaki Er-5 C5P
Past: 2012 Yamaha Ybr 125, 2004 Yamaha Neos 50, 1994 Suzuki Gn 125, 2005 Aprilia Sportcity 125, 1988 Yamaha Tzr 125
Theory: Passed... Mod 1: Passed 22/08/12 Mod 2: Passed 22/10/12
jamieward
PostPosted: 22:03 - 12 Mar 2013    Post subject: Reply with quote
have you tried putting abit of petrol down in the sparkplug hole mate might give it abit of luck and I allways though that the light comes on normally when the bike isn't ticking over
first bike was a derbi gpr 50 Very Happy got some right looks when I fired up lol Very Happy
second bike is a tuono rs 125 Very Happy love the bike keeps up with the 600's Very Happy
tom_m
PostPosted: 22:08 - 12 Mar 2013    Post subject: Reply with quote
Not tried that yet, as i aint pissing around with his bike in the dark whilst he's at his mauds getting his nuts, il try that tomorrow.
when you first turn the key the orange light comes on (constantly lit) for about 5 seconds, during this point you can hear the electronic fuel pump buzzing. the light should go off after that.
When im trying to start the bike it comes on for the five seconds and whilst trying to start it turns over with light constantly flashing/pulsing.
Alpha-9
The way the light flashes will be a fault code
How many times does it flash and in what timing?
Ie. pulsing slowly/quickly
I had that once..think it was just a knackered/low battery Thumbs Up
When it's too low the injectors can't work, FI madness
Fzr-600 1999
tom_m
PostPosted: 22:10 - 12 Mar 2013    Post subject: Reply with quote
it flashes constantly very quickly whilst its turning over, once you let go of button it stops flashing.
Wonder if its a fuelling issue? i should of turned my ybr off whilst trying to start his to see if the pump is buzzing when ignition is turned on
Alpha-9
PostPosted: 22:12 - 12 Mar 2013    Post subject: Reply with quote
They whirr up loudly for a few seconds when you switch the ignition on (before starting the bike) and stop, if you've got a multimeter i'd test the battery voltage, YBRs hate having low power I swapped out for a motobatt was sweet as a nut then
if you've got two ybr's swap batteries and see what happens
I doubt it's fuelling tbh as the ECU does it all, if it is it's bad though
Fzr-600 1999
tom_m
PostPosted: 22:14 - 12 Mar 2013    Post subject: Reply with quote
This could make sense, he only uses bike to commute to/from work (5 miles each way) and to his bints.
Il put my battery on it tomorrow and give that a whirl.
sorry about the 21 questions but i believe it runs the same engine as my 2012, but it has a kick start fitted. Do they run the same management as ive never had a problem with mine Confused
Alpha-9
PostPosted: 22:18 - 12 Mar 2013    Post subject: Reply with quote
Even with the kick start it still needs the injectors running pumping fuel into the bike I think Thinking
Does it run by kick over? What happens then?
2012 doesnt have a kickstart? Bloody modern bikes Razz
My battery got fucked after crashing a few times, stopped holding it's charge, except with mine when you switched the ignition on the management light would be pulsing constantly (or the N light on chinese clocks)
Not managed to bump one either Evil or Very Mad
Turn the highbeam on and try the horn, does it sound weak?
Fzr-600 1999
tom_m
PostPosted: 22:25 - 12 Mar 2013    Post subject: Reply with quote
When you try to kick it does the same, the light pulses constantly. The 2012 doesnt have a kickstart Sad , but it does have a big black grommet where the kickstart is on the 2008 one so im assuming one could be fitted (yam cutting costs ey Laughing ?).
I never tried using the rest of the electrics, as these stoopid ybr's dont have a headlight switch and full lights will only come on once the engine is started. Im gunna go round in morning and have a proper look, swap batteries over and check electrics etc.
Id ask my bro to help me but after the comment he gave me the other day i dont thinkso.
"I thought you switched it to high beam when it was night time so you could see easier, wondered why people have been flashing me for the last 6 months" .... what a bellend
gfrancisdev
PostPosted: 23:08 - 12 Mar 2013    Post subject: Reply with quote
just for reference that bike will start without a battery if you kick hard/rapidly enough, though it's probably not too healthy, the rev counter goes nuts and the light barely works
though according to my haynes manual that's a ecu fault code, and is stored until the memory is cleared, the faults that won't let it restart are:
19-no signal from black/white wire between ignition and ecu
30-tip over sensor(triggered)
33-ignition coil
39-fuel injector
41-tip over(bad wiring/faulty sensor)
50-ecu malfunction
the light flashing pattern says which code it is, first number is long flashes, second is short
15 = 1 long flash, 5 short flashes
tom_m
PostPosted: 01:36 - 13 Mar 2013    Post subject: Reply with quote
33-ignition coil
39-fuel injector
50-ecu malfunction
Thanks for that Thumbs Up will get it up on my phone when i have a look in the morning, il report back once ive had a nosey at it.
BG5067
PostPosted: 12:24 - 13 Mar 2013    Post subject: Reply with quote
When i was at my local dealer a few months back someone had the same problem. I was paying attention fully but i remember them saying it means the bike isnt priming the fuel correctly or something.
I might be wrong.
Current. Kawasaki ZX9R.
Theory passed 17/01/2014. Mod 1 Passed 03/02/2014 (0 faults) Mod 2 10/02/2014 Passed (0 faults)
tom_m
PostPosted: 17:32 - 13 Mar 2013    Post subject: Reply with quote
33-ignition coil
39-fuel injector
50-ecu malfunction
Bike is flashing 1 long flash and 9 short flashes. Code 19. Now im currently ripping the bike apart checking the black/white wire from ignition to ecu
gfrancisdev
PostPosted: 20:09 - 13 Mar 2013    Post subject: Reply with quote
was thinking it might be that, a loose wire is probabaly more likely than all the others
smarjoram
PostPosted: 22:23 - 14 Mar 2013    Post subject: Reply with quote
33-ignition coil
39-fuel injector
50-ecu malfunction
where did you find the list of fault codes? I have the haynes manual but can't find them anywhere. I have a fault in my ignition circuit somewhere since scum ripped the battery off my bike Mad
MBK Booster NG '98, YBR 125 '11
Alpha-9
PostPosted: 22:33 - 14 Mar 2013    Post subject: Reply with quote
Long time no speak Wink
What's it doing?
Fzr-600 1999
gfrancisdev
PostPosted: 22:40 - 14 Mar 2013    Post subject: Reply with quote
if you look in the index it tells you section 3B, specifically 3B5-3B6
smarjoram
PostPosted: 22:46 - 14 Mar 2013    Post subject: Reply with quote
It won't start sometimes, the warning light flashes at me. It sort of starts up for a second then cuts itself out. Bloody annoying when you want to set off and you have to fiddle around with everything to get it going..
smarjoram
PostPosted: 16:04 - 15 Mar 2013    Post subject: Reply with quote
33-ignition coil
39-fuel injector
50-ecu malfunction
Yeah i'm getting fault code 19 sometimes as well. Did you fix yours? I'm gonna have to rip the seat and tank off I think to get to the ECU and trace the black and white wire. Sick
smarjoram
PostPosted: 16:05 - 15 Mar 2013    Post subject: Reply with quote
33-ignition coil
39-fuel injector
50-ecu malfunction
kevinheb
PostPosted: 18:13 - 16 Apr 2013    Post subject: Reply with quote
I have also been getting this problem for the last few weeks. The bike eventually gets started by turning the ignition off, and then back on, usually within half a dozen times the engine will keep in. I just had the Haynes Manual delivered today, and this afternoon have taken the left cover off to check the battery and the fuse and the electrics in there which all seem to be ok, so next at the weekend, I will check the wiring at the ignition, and then follow it down to the ECU (although I'm not looking forward to taking the tank off!)
Have you guys had any luck sorting it out??
YBR 125 (sold) > YBR 250 (sold as spares/repair) > F650CS
Alpha-9
PostPosted: 18:19 - 16 Apr 2013    Post subject: Reply with quote
It's part of the ignition black to black white, if you go into your headlight you will see it going into a red block which is your electric start, make sure all the wires are secure, my electric start came loose once and was being weird, somehow
Fzr-600 1999
kevinheb
PostPosted: 20:10 - 16 Apr 2013    Post subject: Reply with quote
I have taken the headlight off, found the black and black/white and quickly inspected the wires, couldn't see anything immediately at fault, will try again at the weekemd when I've more time. Did think that I'd cracked it when I found the dummy red wire in the connector, but that turned out to be the way it should be.
There is a gap of 221 days between these two posts...
simonjb
PostPosted: 14:48 - 24 Nov 2013    Post subject: Possible Solution to Fault Code 19 Reply with quote
I know this is an old thread but no resolution ever seemed to be found, so this may be worth saying. I recently had this issue (error code 19 on start) I know that some have replaced their barrels to no avail but before trying anything else try this.
Wiggle the key in the barrel to see if it starts (or push down when trying to start) if this seems to be the issue:
Try squirting some switch cleaner directly into the igniton barrel (use the little pipe or your key to prop the plastic bit open) and give it plenty. Leave it 5 minutes and hey presto, worked for me.
Could be condensation (as it happens in winter) collecting in the barrel or just dust.
There is a gap of 4 years, 59 days between these two posts...
leroymel
PostPosted: 23:42 - 21 Jan 2018    Post subject: Reply with quote
Hi everybody,
I get the same blinking pattern with my 2010 YBR 125. Trouble code 19. One day the bike would start, and the next not. Sometimes it started again just by insisting a bit.
Switch cleaner spray directly in the ignition barrel worked like a charm for me.
Thanks for your advice.
Mel- from France.
The last post was made 8 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.98 - MySQL Queries: 13 - Page Size: 139.78 Kb
