Is this pain normal then ?
JodieWodie
Reflective Banana
PostPosted: 18:19 - 19 Nov 2004    Post subject: Is this pain normal then ? Reply with quote
As I am a novice at falling off my bike (the object was to stay on and ride it!)...just a question...
does it ALWAYS hurt like this ?...even if just a minor spill ?
I was going at reasonable speed...but not burning it...but today I can hardly move !!
I guess jarring the body like that will obviously have some painful consequences..
Small tasks are nigh on impossible...GOD alone knows how I coped at work today...
I have a vodka Neutral
It is not vodka o'clock yet but I need something...
A massage with Deep Heat would be nice...but my Fiance will be 'too tired' again I guess Wink
Courage doesn't always roar. Sometimes courage is the quiet voice at the end of the day saying, "I will try again tomorrow"
Rory
PostPosted: 18:24 - 19 Nov 2004    Post subject: Reply with quote
You'd be amazed how many obscure muscles you hurt falling off. Thankfully it usually only takes a few days to recover, but unfortunately it seems to be part 'n' parcel of biking.
And it sounds like you need a better fiance Twisted Evil
My Old CBR400RR | Bike Oil FAQ | Petrol FAQ
flat spot
PostPosted: 18:36 - 19 Nov 2004    Post subject: Reply with quote
Yes it does hurt every time. You may not even feel that bad on the same day but the next you'll be as stiff as a brush.
It is however unfortunate as to how I know this. Sad
innominate
PostPosted: 18:42 - 19 Nov 2004    Post subject: Reply with quote
Lots of long hot baths helps quite a bit.
Otherwise its sit and wait it out :/
Robby
Dirty Old Man
PostPosted: 18:43 - 19 Nov 2004    Post subject: Reply with quote
Yup. Every time. Bigger crashes it hurts like that for several days.
The bit I hate is when I get a dry mouth after the adrenalin has worn off, normally about 1 or 2 hours after the crash. Then the big pain kicking in an hour or two after that is never nice.
mr.z
PostPosted: 19:19 - 19 Nov 2004    Post subject: Reply with quote
The biger your bike is the biger chance of a very painfull bining... i only ever dropped my cg at about 10 mph, and was debateing weather to wear my textile trousers or or not very morning, lucky for my legs i did!
The main thing is to get back on as soon as possible, the longer you leave it the more scarey a prospect of hoping back on will be Sad
JodieWodie
Reflective Banana
PostPosted: 19:22 - 19 Nov 2004    Post subject: Reply with quote
Haha..I didn't have much choice did I !!????....
my test was a few hours later !! Wink
I didn't want to get back on...it was BUCKETING it down with rain...but I gathered all my determination and just got on with it....
glad I did Thumbs Up
PostPosted: 19:26 - 19 Nov 2004    Post subject: Re: Is this pain normal then ? Reply with quote
JodieWodie wrote:
does it ALWAYS hurt like this?
Yeah, but you get used to it after a while.
When I come off earlier in the summer at about 30mph, I was fine apart from my shoulder which joyfully dislocated itself. The next day, I couldnt get out of bed. Every muscle in my body ached for about 2 weeks, my back especially.
I just put it down to whiplash. Rolling Eyes
You'll be fine in a few days, just need to rest. Smile
Aprilia RSV Mille R Edwards Replica - Aprilia RS250 - Suzuki GSXR600 Supersport Race Bike
Sparks!
Sir Tart-a-lot
PostPosted: 19:41 - 19 Nov 2004    Post subject: Reply with quote
You always do muscles in when you fall off, no idea where, smallest of drops and you'll hurt yourself for some reason... I had a bit of an er indident on the WR last sunday and was aching till Wednesday and all I did was sort of get highsided off it then run into a ditch Mr. Green so even the smallest accident will hurt Smile
PostPosted: 19:47 - 19 Nov 2004    Post subject: Reply with quote
You wanna try highsiding at 70mph, sliding for a bit then ragdolling the last 50 yds. You think you have walked away totally uninjured but the next morning...
Oohyafucker etc.
Flip
PostPosted: 19:53 - 19 Nov 2004    Post subject: Reply with quote
Always hurts, you just get less suprised each time it happens. In a great of pain right now as it happens Evil or Very Mad
Rory
PostPosted: 19:55 - 19 Nov 2004    Post subject: Reply with quote
Or going through barbed-wire fence and straight into a hillside covered in nettles. Ow.
Still made it to work the next day though.
goony
PostPosted: 21:00 - 19 Nov 2004    Post subject: Reply with quote
get checked out at hospital or doc`s very easy to ignore pain but if you`ve damaged something you can make thing`s worse and suffer later in life like i now do
nc30 chick
PostPosted: 21:35 - 19 Nov 2004    Post subject: Reply with quote
I always find it hurts more the next day, not sure if its because the adrenalines pumping when it first happens.
Bruises and sore muscles are the norm I've found out Embarassed
mchaggis
PostPosted: 21:37 - 19 Nov 2004    Post subject: Reply with quote
You mentioned previously that you thought you'd fractured your finger? I should have thought that would be painful enough if it was. If it hasn't swollen up and is still moveable it's probably not broken?
It always hurts to fall off, even if it's just a bin at 15 mph. I should hope you'll be back to normal in a week or so.
I must not be a troll...
Mmmm, Guinness
mattsmith95
PostPosted: 01:09 - 20 Nov 2004    Post subject: Reply with quote
I've had accidents, mainly at slow speeds (10mph - 20mph)
and no matter what happens, it hurts!!
OR
You maybe okay now but in a couple of hours, AHAHHHAHHAHA!
The last accident, which was about 3 years ago, doing about 10
mph when a white van did a U turn knocking me clean off. Buggered up my shoulder for about 2 weeks and after that I had
problems lifting my arm higher than my head, the pain was bad.
bottom line is accidents at slow speeds can hurt like hell, nice
hot baths are the answer.
NickD
PostPosted: 01:14 - 20 Nov 2004    Post subject: Reply with quote
It's about luck Jodie.
A couple of years ago I t- boned a car at around 50 mph, got up, had a bit of a shout, broke nothing, and felt nowt. Woke up the following day a little stiff, but with no major problems........Last week however, I stubbed my toe on my bed post, and could have cried like a little girl.
All about luck! Thumbs Up
I was only doing what it said on my licence officer....
Tear along the dotted line!
hustler
PostPosted: 21:14 - 20 Nov 2004    Post subject: Reply with quote
The older you are the more it hurts Shocked
As I said to that guy with the crutches and full camouflage gear, you can hide but you can't run.
lurker
PostPosted: 00:59 - 21 Nov 2004    Post subject: Reply with quote
if youve got quality gear on it doesnt necessarily involve pain.
if you tense up and hang on for dear life its more often than not gonna hurt but if you have the presence of mind to let the bike go and your bodys relaxed when you hit the ground youve got less chance of injury.
easier said than done though
couple of offs ive had have been low sides.
once on a bend and the other on a roundabout.
both times there wasnt much warning and didnt get time to react think thats why i was pretty much relaxed when i hit the ground and the bike went its own way.
only thing that hurt was my wallet
iCraig
PostPosted: 01:03 - 21 Nov 2004    Post subject: Reply with quote
I crashed in August 2002, and damaged my hip pretty badly then.
The bloody thing still hurts now!
So yes the pain is really this bad. Razz
Frost
PostPosted: 04:33 - 21 Nov 2004    Post subject: Reply with quote
Shatterd my left wrist hitting the ground as god knows what speed :S
Hurts like hell when it gets cold Sad
Often when you crash you slightly pull/tear ligaments, muscules, tendons, or put hairline cracks into bones. These ache for a few days, but after a few weeks your back to normal.
california_rookie
PostPosted: 05:07 - 21 Nov 2004    Post subject: Reply with quote
Yeah, we seem to forget how much cartilage dislikes being compacted in a fall. This usually causes a bit of swelling in between the vertebrae which can be very unpleasant. If it wasn't much of a tumble, I'm sure you'll be fine in another day or two. Just don't overdo it with the vodka. If there is such a thing. Thumbs Up
https://www.bikepics.com/members/californiarookie/04gsxr600/
https://www.myspace.com/spapadillion
https://steamcommunity.com/id/spapadillion
CBRPETER
PostPosted: 07:28 - 21 Nov 2004    Post subject: Reply with quote
i came off a wr450 the other week at about 40 km/h, fell on soft grass, got up and thought nothing of it, the next day me knee was bunged up good as was my shoulder.
Shes my life, shes so rad and shes the best ride i ever had!!
PostPosted: 14:28 - 21 Nov 2004    Post subject: Reply with quote
[said while touching wood]
I've fallen off plenty of times and not hurt myself.
Infact, the only time I've hurt myself more than I have done on a push bike is when I fell of the back of a bike doing a wheely at around 60mph.
I have hurt myself plenty, but have also crashed and not really hurt myself.
Crashing at Snetterton (front end went under braking in the wet) recently I had a very slightly achey shoulder... but seemed to hurt less the next day than others that had done the full day, but had not crashed.
I've also crashed on the road a few times and not hurt myself at all. Usually when leaning the bike so I'm not so far off the road.
Fallen Angel
Franny the Nanny
PostPosted: 14:55 - 21 Nov 2004    Post subject: Reply with quote
Hey Jodie - sorry to hear you came off too!!
Tis the season to be falling
Tra-la-la-la-la La-la-la-la Laughing Laughing
Sorry couldn't resist that hon. Seems like you had a worse time than me - what happened, I can't find a thread about it?
Fran Thumbs Up Karma Thumbs Up
x
I have an asshole tolerance level of -10 Twisted Evil
Mr. Green Dance! Mr. Green www.cliqueyclanmcc.co.uk Mr. Green Dance! Mr. Green
www.bebo.com/fallenangelfran
The last post was made 21 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 132.03 Kb
