Weight of beans vs concrete
mic
PostPosted: 21:24 - 13 Mar 2013    Post subject: Weight of beans vs concrete Reply with quote
Long boring story short..... A fridge pack of heinz beans says 1kg on the label. If I eat the beans and pour some ready mix concrete in the empty tub, how much will it weigh?! How am I suppose to work it out without doing it?!
Cheers ta!
zzr600
Derivative
PostPosted: 21:28 - 13 Mar 2013    Post subject: Reply with quote
You need to know the density of concrete, and the volume of the container.
The tub has a specific volume.
An easy way to measure the volume would be to fill it with water and weigh it. 1 kg of water = 1 litre (0.001 m^3) to a reasonable approximation.
Once you have that volume, you multiply it by the density of concrete.
Wikipedia tells me:
https://en.wikipedia.org/wiki/Properties_of_concrete
'The density of concrete varies, but is around 2,400 kg/m³'
Or 2.4kg per litre.
Put that way, a 2L bottle of coke would hold 4.8kg of concrete.
Thinking about it - it might be reasonable to assume beans are about as dense as water. A tin of beans weighs about 400g and it's about the same volume as a 330ml can of coke.
Islander
PostPosted: 21:30 - 13 Mar 2013    Post subject: Reply with quote
Concrete weighs 2400kg/m3. Work out the volume of the tub, do some division. Thumbs Up
carvell
Scuttler
PostPosted: 21:31 - 13 Mar 2013    Post subject: Reply with quote
You need to know the density of both, https://www.aqua-calc.com/page/density-table will help you.
Work out the volume of beans that equates to 1kg, then work out how much the same volume in concrete weighs.
[edit] beaten...
Yamaha TDM 850
Tristan.
PostPosted: 21:33 - 13 Mar 2013    Post subject: Reply with quote
volume of a 410g tin of beans is apparently 0.043m^3 (you could work it out by measuring it to check) so that gives a relative density (assuming ~50g for the tin) of 0.84. The relative density of concrete is ~2.4. No point being precise given the amount of assumptions. Concrete is about 3 times as dense as beans, so it would weigh 3kg.
mic
PostPosted: 21:36 - 13 Mar 2013    Post subject: Reply with quote
This is all good but am I correct to base it on 1kg of beans and not 1kg of water, or is it 1kg volume regardless of what's in it?
zzr600
Derivative
PostPosted: 21:41 - 13 Mar 2013    Post subject: Reply with quote
A kilogram is a unit of mass (we use it for weight as well, sort of).
Volume is measured in litres or metres cubed (m^3).
Volume refers to the size of the object. Balloons for example are very voluminous but pretty light.
1kg refers to the mass of the beans, nothing to do with the container. The container is the size that happens to fit 1kg of beans (it'd fit a gram of air, or a few kilograms of gold, for example).
I used water earlier because water is pretty similar to beans in terms of density. Get a can of beans and a can of coke (basically water). They're not exactly the same, but within 25% on both mass and volume.
mic
PostPosted: 21:44 - 13 Mar 2013    Post subject: Reply with quote
Cool, sounds like it might just do the trick then Very Happy will try it friday and see what happens
Cheers people Thumbs Up
zzr600
Flatbadger
PostPosted: 23:33 - 13 Mar 2013    Post subject: Reply with quote
What's the density of beans? Brilliant! Laughing
Ground anchor? Or is someone going to be sleeping with the fishes?
You're in ISIS
mic
PostPosted: 04:51 - 14 Mar 2013    Post subject: Reply with quote
Who da man! Yeah it's for a little boat I'm picking up soon.
zzr600
The last post was made 13 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 63.74 Kb
