| scooke |
 scooke Borekit Bruiser
| stinkwheel |
 Posted: 14:40 - 14 Mar 2013 Post subject: |
It'll be a dodgy switch in the safety interlock system. There are three, the clutch switch, the sidestand switch and the neutral switch.
Probably the sidestand switch, it's designed to cut out if you engage a gear with the stand down. If the switch is broken in such a way as the bike thinks the stand is still down, the engine will start in neutral cut-out as soon as you engage first.
A faulty clutch switch would prevent you using the starter in first with the clutch pulled in.
EDIT: Most of these problems can be bypassed by pulling the snap connector to the clutch switch apart and bridging between the two wires that are not light green. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| scooke |
| stinkwheel |
 Posted: 14:54 - 14 Mar 2013 Post subject: |
Make up your mind.
You said in your first post that it starts but stalls when put in gear.
Now you say it won't start at all?
Which is it?
Is the neutral light coming on? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| scooke |
| stinkwheel |
 Posted: 15:12 - 14 Mar 2013 Post subject: |
It is almost certainly the safety interlock system.
Here's a wiring diagram of just the starter circuit.
EDIT: Also find the main fuse box and give it a thump. There is a microrelay in there that has to click before the solenoid can activate. Sometimes sticks. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| scooke |
The last post was made 13 years, 223 days ago. Instead of replying here, would creating a new thread be more useful? |
