DOT3? Will DOT 4 do?
Gazz
PostPosted: 16:58 - 14 Mar 2013    Post subject: DOT3? Will DOT 4 do? Reply with quote
On my bike (GPZ600R 1990 model) it says on the brake reserviour that ONLY DOT 3 fluid should be used, however, I was wondering what would happen if I used DOT 4?
Surely DOT4 is better.
Discuss. Wink
Tungtvann
PostPosted: 17:06 - 14 Mar 2013    Post subject: Reply with quote
DOT 4 replaced 3 as far as I know, so should be better but at very least the same.
The Artist
PostPosted: 17:07 - 14 Mar 2013    Post subject: Reply with quote
DOT4 is for higher temps and is more expensive.
If the manufacturer recommend DOT3, I would use DOT3. I don't think it would cause any damage using DOT4 but it is a waste of money. It is designed for higher performance brakes. DOT4 also absorbs less moisture so DOT3 is better on the wallet and longevity.
Do not use DOT5 though, that is totally different stuff.
CaNsA
PostPosted: 17:10 - 14 Mar 2013    Post subject: Reply with quote
DOT4 handles higher heat. If your bike is calling for DOT3, that means that the manufacturer does not feel that the braking system will not raise the brake fluid above a temperature that DOT3 can handle.
DOT4 will be fine IMO.
Shinigami
PostPosted: 17:18 - 14 Mar 2013    Post subject: Reply with quote
Just don't use DOTT or the world will be taken over by garishly coloured characters
https://www.cosplayisland.co.uk/files/costumes/11/551/Dott-screenshot.png
map
Mr Calendar
PostPosted: 17:28 - 14 Mar 2013    Post subject: Reply with quote
DOT 4 will be fine.
DOT 4 is probably more readily available, the likes of Asda and Tesco sell it after all.
Just don't open up the debate between DOT5 and DOT5.1
Ooopps. Wink Razz
doggone
PostPosted: 17:39 - 14 Mar 2013    Post subject: Reply with quote
There are some types of brake fluid which are incompatible with some systems, as they attack the rubber seals and can cause expensive damage - I'm thinking of some tractors but also Citroen cars you really had to watch what you put in even a little top up of the wrong stuff would prove expensive.
supZ
PostPosted: 18:01 - 14 Mar 2013    Post subject: Reply with quote
this.
the bike is 23 years old, DOT 3 was probably all that was available back then..
CBR954RR - Daily toy
CBR600RR - Trackbike
The last post was made 13 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 55.13 Kb
