Locking a flywheel for removal?
mudcow007
PostPosted: 13:30 - 15 Mar 2013    Post subject: Locking a flywheel for removal? Reply with quote
went to attack my oil leak last night, but stumbled at the first gate
how in gods green earth do you get the nut off the flywheel?
i tried sticking the bike in 5th an trying it that way but the flywheel still turned.
i didnt really fancy wedging something through the flywheel as thought it might damage something
i reckon a buzz gun would get it off, but im lacking said buzz gun
answers on a postcard please
PostPosted: 13:35 - 15 Mar 2013    Post subject: Reply with quote
Fold a piece of stout cloth over four or five times. A piece of denim is ideal. Jam it in the teeth of the primary transmission to stop it turning.
OR
Put the bike in gear and hold the back brake on.
mudcow007
PostPosted: 13:38 - 15 Mar 2013    Post subject: Reply with quote
nice, will try that
thanks
Nick_Giles
PostPosted: 13:47 - 15 Mar 2013    Post subject: Reply with quote
Also (not sure about the CG) but some flywheel retaining bolts are a left hand thread.!
You got a flywheel puller.?
Nick
mudcow007
PostPosted: 15:02 - 15 Mar 2013    Post subject: Reply with quote
yeah got one from buster which screw into the flywheel an pops it off, if that makes sense
Cyclingbiker
PostPosted: 17:08 - 15 Mar 2013    Post subject: Reply with quote
I used a chain wrench to hold the flywheel steady whilst I undid the nut, it was a tight bugger and the spanner needed tapping with a hammer while applying steady pressure to shock the nut free. I did try to use a rubber strap wrench to hold the flywheel but I found it slipped to easily under heavy load. The chain wrench has teeth on the part of the handle that contacts the flywheel that dig in if you apply pressure the right way and hold it rock steady. It didn't mark the outside surface too badly when I did it so I wouldn't worry about that Thumbs Up
https://www.toolstation.com/shop/Automotive/Mechanics+Tools/Chain+Wrench+300mm/d60/sd180/p56261
The actual removal of the flywheel was comparatively easy using the LH threaded flywheel puller I got from Wemoto. You screw it in with the central rod backed all the way out then wind it back in to push the whole thing off of the shaft. It can be a tight fit, especially if it has never been removed so be wary.
Honda CB500s (1999) - Honda CG 125 BR-J (1991)
Mod 1 - Passed - 12/11/12 --- Mod 2 - Passed - 26/11/12
The last post was made 12 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 48.3 Kb
