WD40 on chain?
Gazz
PostPosted: 16:50 - 15 Mar 2013    Post subject: WD40 on chain? Reply with quote
I have heard that you shouldnt use WD40 on a chain... is there any reason for this?
I remember using it on a bicycle chain years ago and use it on a lot of other motorcycle parts, but why is it seen as a no-no for chains?
I used to use Chain cleaner and chain lube but have recently resorted to using old engine old to lube the chain, but dont see what could be wrong with using WD40.
Islander
PostPosted: 17:08 - 15 Mar 2013    Post subject: Reply with quote
WD40 isn't a lubricant, it's a water dispersant. The solvents may damage the 'O' rings. It's completely unsuitable for the job.
Cleaning the chain, use paraffin or diesel.
Lubricating the chain use EP90 gear oil (miles better than engine oil, recommended by manufacturers, viscous enough not to fling and cheap as chips) or an aerosol chain lube.
RhynoCZ
PostPosted: 17:31 - 15 Mar 2013    Post subject: Reply with quote
WD40 would do no harm to the chain, but it'll dry out/evaporate soon and the chain would end up dry/with no lube on it.
Islander
PostPosted: 17:39 - 15 Mar 2013    Post subject: Reply with quote
I wouldn't assume that it does no damage - the 'O' rings might not handle it well.
BikerMatt
PostPosted: 17:49 - 15 Mar 2013    Post subject: Reply with quote
I've had this in my bookmarks for a while, pretty useful stuff.
https://www.xt225.com/forums/ubbthreads.php?ubb=showflat&Number=33659
So many bikes..
Islander
PostPosted: 18:01 - 15 Mar 2013    Post subject: Reply with quote
That's interesting. Thumbs Up
RhynoCZ
PostPosted: 18:12 - 15 Mar 2013    Post subject: Reply with quote
WD40 came out quite alright, I guess. Anyway, get some proper chain lube, I use Valvoline white synthetic chain lube, not expensive, works quite well Thumbs Up
https://www.autokaubad24.ee/images_products/4f9567280825b.jpg
Islander
PostPosted: 18:14 - 15 Mar 2013    Post subject: Reply with quote
EP90 is cheaper by far Razz Wink
RhynoCZ
PostPosted: 18:20 - 15 Mar 2013    Post subject: Reply with quote
6.25GBP for the can and I got it 2 yrs ago and it's still not empty + the bike stays clean Smile
Well, I don't ride my motorcycle in rain/wet, so I don't need that much of it.
Copycat73
PostPosted: 18:24 - 15 Mar 2013    Post subject: Reply with quote
i had to gooogle LPS Laughing
a interesting dam good read... Thumbs Up
seems whatever you use has a negative impact Neutral
caveat emptor
The last post was made 12 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 65.14 Kb
