Suzuki GZ 125 starting issues
GeordieChambe...
PostPosted: 23:43 - 19 Mar 2013    Post subject: Suzuki GZ 125 starting issues Reply with quote
Hi there everyone Smile I'm a complete newbie to biking and have purchased a 53 reg Suzuki GZ 125 for £250 and I already knew it had starting/battery issues. I was told by the seller that it would probably need the battery recharged (which I had a feeling off the price was a load of **** Wink ).
Anyway I've had the battery fully recharged but when I started the bike with the electric start (no kick start Sad ) it made a coughing and spluttering noise then finally started so I duly set off but 20mins later after I stopped, it took ages to start then after riding another 30 mins and stopping it refused to start (so I had to bump her).
I've got her safely in my house now but when I have the ignition on and in neutral she refuses to start and just makes a clicking sound from the right hand side next to my seat (looks like a plastic relay???). The lights dim slightly when I press the button but no engine or any sort of starting noise, also my headlight, rear light and indicators all work perfectly so in my mind in can't be the battery (but I'm new so I could be wrong). Any help with this would be really appreciated as I would rather learn to do all my bike repairs myself (within reason of course) than fork out taking it to a garage. Cheers, David Very Happy
Suzuki GZ125 (03) - March 2013, CBT - April 2013
stoke-gaz
PostPosted: 00:01 - 20 Mar 2013    Post subject: Reply with quote
Sounds like a starter motor issue to me mate, try connecting the battery direct to the motor, +ve lead to the connection on the motor, -ve to the motor body.
If it spins its a wiring issue somewhere between the solenoid and the motor, if it doesnt spin its buggered.....
HTH...
Gaz.
Ex: GZ125HS, Current: Yamaha xv535 virago, Suzuki GSF600.
CBT: passed 30/09/2012 Theory: passed 02/02/2013 MOD 1: 27/03/2013 MOD 2: 18/04/2013.......CAT A LICENCE IS MINE!!!!
GeordieChambe...
PostPosted: 00:05 - 20 Mar 2013    Post subject: Reply with quote
Thanks for the quick reply Gaz Smile. Do you know where my starter motor would be located on the bike mate?????
stoke-gaz
PostPosted: 00:09 - 20 Mar 2013    Post subject: Reply with quote
No probs mate, front of the engine behind and below the horn, IIRC two 10mm bolts holding it on.
Gaz.
GeordieChambe...
PostPosted: 00:20 - 20 Mar 2013    Post subject: Reply with quote
Cheers Gaz sure I've found it, looks like a circle tube in front of my oil reservoir Smile How would I make the positive connection though, as my battery lead isn't long enough to get there???? Take the starter motor out????
stoke-gaz
PostPosted: 00:38 - 20 Mar 2013    Post subject: Reply with quote
Take out your spark plug, and connect starter motor to batter with a set of jump leads, or take the motor off and connect up, just make sure your foot is on the motor, they dont half have a kick with power through them....
Gaz.
GeordieChambe...
PostPosted: 00:48 - 20 Mar 2013    Post subject: Reply with quote
Thanks Gaz just done that and the starter motor is totally dead not even making a sound Smile Is there anything that could have caused it to fail or is that just general wear and tear? (the bike has 16,494 on the clock and the starter motor looks like the original, i.e blistered and worn casing)
stoke-gaz
PostPosted: 00:56 - 20 Mar 2013    Post subject: Reply with quote
Have you tried another battery, just to make sure its not that thats dead?
Motor brushes can go over time, tbh i'm not sure how long they should last.
If it still doesn't turn with a different battery, time to get the multimeter or continuity tester out and check the wire between the battery and solenoid and solenoid and motor connection.
Gaz.
GeordieChambe...
PostPosted: 01:01 - 20 Mar 2013    Post subject: Reply with quote
I haven't tried another battery yet (which I should have today as I was out riding with a friend when this happened Sad ) but I will first thing in morning when my friend pops up Smile. I'll post back to let you know how it went Gaz. Thanks for the help you've gave me now though mate, I'm glad I joined this place now Very Happy
stoke-gaz
PostPosted: 01:03 - 20 Mar 2013    Post subject: Reply with quote
no worries mate, will keep an eye on this thread tomorrow.
Definitely a cracking bunch of guys on here, always ready with help, advice and piss taking where needed Cool
Gaz.
Efes123
PostPosted: 06:14 - 20 Mar 2013    Post subject: Reply with quote
You can always open it up, and have a look at the bushes. Hope it doesn't look like this;
https://gallery.dogfriendlysuffolk.com/albums/BikePics/Suzuki/normal_Suzuki-starter.jpg
Seriously though, it's rare for a starter motor to fail on a 12 year old bike, at least a 12 year old Jap bike. Sounds like you got a good bargain if that and the battery are the only things wrong with it though. Let's see some pics.
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
GeordieChambe...
PostPosted: 09:47 - 20 Mar 2013    Post subject: Reply with quote
Right lads I've tried another battery and that hasn't solved the issue and also opened the starter motor up and it looks fine albiet a little dirty but thats been cleaned up and I now stuck on where to check next. Loaded some pics of the bike up though.
Efes123
PostPosted: 09:58 - 20 Mar 2013    Post subject: Reply with quote
Two things to try; if the starter is off the bike, then try connecting it up to a battery and see if it turns. Be careful, it gives a hell of a kick when it starts so it'll need either standing on, or best, put in a vice.
If the starter is on the bike, then check the charge to it using your multimeter.
When you try to start it, does it make a single click, or multiple ones?
GeordieChambe...
PostPosted: 10:03 - 20 Mar 2013    Post subject: Reply with quote
I'll check them now but click wise it makes one click when I press the electric start then another when I depress (like an on/off click) Smile
GeordieChambe...
PostPosted: 10:22 - 20 Mar 2013    Post subject: Reply with quote
Checked the starter with the multimeter and thats fine. Completely at a loss now Sad haha
Efes123
PostPosted: 10:37 - 20 Mar 2013    Post subject: Reply with quote
So, there's power getting to the starter motor, but it's not turning?
GeordieChambe...
PostPosted: 10:39 - 20 Mar 2013    Post subject: Reply with quote
Yeah there's power there, when I press the start button I can hear it whirring after the click but then dies out
Efes123
PostPosted: 10:55 - 20 Mar 2013    Post subject: Reply with quote
OK, so just to be sure. The starter motor wasn't working, but now is, but the bike still isn't starting? Not sure what you mean when you say
it dies out
Do you mean it isn't firing, or the starter somehow gives up the ghost?
GeordieChambe...
PostPosted: 10:58 - 20 Mar 2013    Post subject: Reply with quote
When I say die out I mean it makes a slight whirring noise as if it is going to kick in but then fades to silence then I'm just left with that dumb clicking Sad lol
GeordieChambe...
PostPosted: 11:08 - 20 Mar 2013    Post subject: Reply with quote
Right now the bike is sounding weird, when I'm pressing the start button its sounds like the starter motor and the battery are squealing but it won't fire up ???? wtf???? Sad
Efes123
Could be your solenoid is toast. Try shorting it e.g. place a screwdriver across the terminals and push the starter button. You may get a few sparks, don't worry.
GeordieChambe...
PostPosted: 11:13 - 20 Mar 2013    Post subject: Reply with quote
And now it's just completely died off and is not even making a click from the start button Sad this is really getting annoying now lol tried the solenoid and it sparks when I place my screwdriver over both heads.
Efes123
PostPosted: 11:29 - 20 Mar 2013    Post subject: Reply with quote
OK, now I'm afraid I'm running out of ideas. This is really simple mechanics, but it's not making sense. Have a look at this youtube video, one of the best to explain how it all works;
https://www.youtube.com/watch?v=dGem9YsjCRQ
I'll have a think...
EDIT: Sorry, I'm a bit stumped, it could be the solenoid, or it could be the starter, or it might just be something else all together Crying or Very sad
You did try starting it with the solenoid shorted?
GeordieChambe...
PostPosted: 17:08 - 20 Mar 2013    Post subject: Reply with quote
Right after much brainstorming and after inspecting each part about 20 times over I've finally realised that the starter motor was on it's last legs this morning and has packed in completely. I'm sure that it must have shorted my solenoid as well as I'm not getting a reading on the side that is linked to the starter. Does that sound about right to anyone???? Smile
Efes123
PostPosted: 09:04 - 21 Mar 2013    Post subject: Reply with quote
Just a thought, have you tried bump starting it?
The last post was made 13 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 137.58 Kb
