Engine Oil (Again)
Mark65
PostPosted: 10:07 - 20 Mar 2013    Post subject: Engine Oil (Again) Reply with quote
Hiyas
So in my old YBR I used Silkoline Comp 4 at about £9 a liter, has anyone tried the Asda 5w40 synthetic at £10 for two liters? or even the 5w30 for the same price.
There is also Silkolene - Scoot Go 4 5W-40 for £7.50 plus delivery.
I have tried carlube diesel oil in the past on the YBR and it seemed ok for the 1k I had it in.
Mark
PostPosted: 10:26 - 20 Mar 2013    Post subject: Reply with quote
How often are you changing.
Your CG can use worse oil than my 125 and my 125 uses 10w40 Tesco/Morrisons mineral oil.
Why spunk loads on oil for a CG unless you are made of money...
Mark65
PostPosted: 10:43 - 20 Mar 2013    Post subject: Reply with quote
It will work out at 600 miles a month commuting so every 1200miles or two months most likely, similair to what I did on the YBR. Asda do a 5w30 semi for £4 a liter.
And no lol Im not made of money this is why I bought the cg, should save me £80 amonth compared to the car.
Thanks
Mark
PostPosted: 11:19 - 20 Mar 2013    Post subject: Reply with quote
4 litres for £12 at Morrisons.
Change oil every 1500-2000 miles. You'll be fine.
Mark65
PostPosted: 15:07 - 20 Mar 2013    Post subject: Reply with quote
Cheers, I will have a look.
Mark
mudcow007
PostPosted: 15:20 - 20 Mar 2013    Post subject: Reply with quote
saves starting a new thread but.....
without opening a can of worms
normal car oil in my CG?
if i use tescos/ asda/ sainsburys or if im feeling really flush waitrose 10w40 oil in my old CG will it implode on its self causing a small nuclear explosion or will it be fine?
ive heard car oils can reek havoc on wet clutches?
or like the vicar says "should i just stick some in an see what happens"
PostPosted: 15:27 - 20 Mar 2013    Post subject: Reply with quote
Be fine, only ever used car oil in my bikes, nothing wrong.
mudcow007
PostPosted: 15:40 - 20 Mar 2013    Post subject: Reply with quote
bobby dazzler thanks uncle Paddy
stuarthouston
PostPosted: 16:21 - 20 Mar 2013    Post subject: Reply with quote
I use this in my CG based on the fact that it was the cheapest I could find at the time:
https://www.carparts4less.co.uk/cp4l/c/Toyota_Yaris_1.0_2003/p/car-parts/car-lubricants-and-car-fluids/lubricant-and-fluids/engine-oil/?521776011&1&5b180548c18b8010eb3e8f8d23a4ec20faad8020&000398
PostPosted: 16:23 - 20 Mar 2013    Post subject: Reply with quote
Nice deal on that oil Thumbs Up
stuarthouston
PostPosted: 16:36 - 20 Mar 2013    Post subject: Reply with quote
Marginally cheaper again on their eBay shop. 5l for £12.90. Delivery is super fast as well. Thumbs Up
https://www.ebay.co.uk/itm/Triple-QX-10W40-Semi-Synthetic-Engine-Oil-5-Litre-/300744315280?pt=UK_Vehicle_Oils_Lubricants_Fluids&hash=item4605c21190
hondakawasaki
PostPosted: 17:04 - 20 Mar 2013    Post subject: Reply with quote
I use asda 10w40 oil £8 for 2 liters in my cg i change it every 600ish miles
i did use some castrol 15w40 in my cg once it was on sale 4l for £8 i only did about 20miles before it knackered my clutch it made the clutch slip like f**k i had to buy new clutch plates in the end
Walloper
PostPosted: 17:35 - 20 Mar 2013    Post subject: Reply with quote
£80/month on engine oil???
Do you have a leak?
If you are bothered so much about changine the oil then why are you asking what cheap shite can I use.
I would use the best I can afford and use that 'better' kwolity to allow some extension in mileage. (And fix that damned leak)
Mark65
PostPosted: 20:40 - 20 Mar 2013    Post subject: Reply with quote
Lol no, the bike will save me £80 a month in fuel instead of using a car and no queing.
Mark
PostPosted: 20:55 - 20 Mar 2013    Post subject: Reply with quote
My 125 saves me £150 in fuel alone each month.
Shit, it is sooo cheap I forget about it.
PostPosted: 00:17 - 21 Mar 2013    Post subject: Re: Engine Oil (Again) Reply with quote
Mark65 wrote:
Hiyas
5W30 is quite likely an energy saving oil, and if so a good chance it will screw up your clutch.
If you are changing it that often there seems little point in using a synthetic oil. Personally just use a cheap 10W40 mineral oil (assuming 10W40 is the specified viscosity).
von1papen
PostPosted: 12:57 - 21 Mar 2013    Post subject: Reply with quote
Personally I just buy 20/25 litre drums, usually in the £45-60 region depending if you want generic semi synth, or decent Fuchs stuff.
Means a litre of alright semi Synth costs me around £2, and the drum does me for at least a year (plus changing oil for the car)
PostPosted: 13:03 - 21 Mar 2013    Post subject: Reply with quote
From where?
temeluchus
PostPosted: 13:47 - 21 Mar 2013    Post subject: Reply with quote
##Paddy## wrote:
From where?
I recall seeing 50l drums for sale in costco and other places.
DrDonnyBrago
PostPosted: 13:53 - 21 Mar 2013    Post subject: Reply with quote
##Paddy## wrote:
From where?
Costco has big drums of engine oil.
Not sure if it is that cheap though.
Walloper
PostPosted: 15:08 - 21 Mar 2013    Post subject: Reply with quote
It will go off once the air gets to it though...
****Internet Myth Generater Disconnected***
von1papen
PostPosted: 16:12 - 21 Mar 2013    Post subject: Reply with quote
Autowindscreenrepair in Balloo, Bangor does the 25 litre drums for £60 I believe (used to be £45),
And I've a friend in a hirestore who gets 20 litre drums of slightly lesser quality 10w40 semi Synth for £45,
https://www.ebay.co.uk/itm/ELF-10W40-SPORTI-TXI-ENGINE-OIL-20-LITRE-DRUM-/251215747742?pt=UK_Vehicle_Oils_Lubricants_Fluids&hash=item3a7da01a9e
That sort of thing, and obviously from buying locally you've no p&p. Seemingly most autoparts places can get such things, but never advertise them, because they'll make alot more money sticking 4litre/1litre bottles on the shelves
The last post was made 13 years, 241 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 126.63 Kb
