SV650 won't start - wont even bump.
_Troy_
PostPosted: 20:28 - 20 Mar 2013    Post subject: SV650 won't start - wont even bump. Reply with quote
Evening all. Now this is not for my bike, its my brothers, and he's is currently stranded at work with a non working bike.
He says he tries to start it and it just makes a ticking noise from the below location. There is power in the battery, and the longer he holds down the starter, the tachometer needle starts to climb.m
He's tried bump starting it, and after many many many tries, got it to run for 1 or 2 seconds.
So, any ideas? Electrical problem I presume, but that's an assumption from the comfort of my couch.
Problem is he needs this bike for his commute. He lives nowhere near a train station, and travels down the motorway to work. He could have borrowed mine, but we don't live in the same county.
https://farm9.staticflickr.com/8239/8575956502_263d22ba8a.jpg
Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650
kiddakidda
PostPosted: 20:33 - 20 Mar 2013    Post subject: Reply with quote
Well that right there is your solenoid and this will normally make a clicking sound if the battery is low or the solenoid is faulty.
If it bumps starts then the starter solenoid wouldn't prevent it from running once it had started.
Is there any fault codes displayed? Has it been dropped recently?
Could be the Tilt sensor stopping it from running.
Suzuki SFV 650 (Gladdy) > Triumph Street Triple R
_Troy_
PostPosted: 20:36 - 20 Mar 2013    Post subject: Reply with quote
Fault codes?! This is a '00 SV, so none of them. Not dropped as far as I know. It's the tacho that makes us think its electrical.
Paris2
PostPosted: 21:41 - 20 Mar 2013    Post subject: Reply with quote
Right I'm home (talking about my bike)
The bike jumped perfectly fine, and rode fine all the way home.
It did something similar yesterday, when pressing the starter button nothing happened (as if the killswitch was on) but then upon rocking and bouncing the bike slightly it started to start and fired.
Any ideas, dodgy connection somewhere?
Current Ride: Daytona 600
PostPosted: 21:52 - 20 Mar 2013    Post subject: Reply with quote
Battery and earth points.
Clean up the solenoid.
Paris2
PostPosted: 22:02 - 20 Mar 2013    Post subject: Reply with quote
Ill give it a good going over at the weekend.
Will just limp through the rest of the week Laughing
Copycat73
PostPosted: 08:52 - 21 Mar 2013    Post subject: Reply with quote
if cleanin the solenoid connections don`t work have a look at the brushes in the starter motor.
caveat emptor
PostPosted: 08:58 - 21 Mar 2013    Post subject: Reply with quote
Just strip and service it if need be. But I'd look at battery and solenoid.
If it does stick again, put in 2nd and rock back and forth in gear.. then pull in clutch and start.
kiddakidda
PostPosted: 12:13 - 21 Mar 2013    Post subject: Reply with quote
So you rocked it and it started?
I'm not saying it is but it's worth checking your tilt sensor as previously advised.
kiddakidda
PostPosted: 02:27 - 24 Mar 2013    Post subject: Reply with quote
Did you sort it Mucka?
AlexW
PostPosted: 13:58 - 24 Mar 2013    Post subject: Reply with quote
Just FYI, old SV's don't have a tilt sensor, when dropped they cut out due to the carbs.
sidewinder
PostPosted: 18:22 - 24 Mar 2013    Post subject: Reply with quote
Try cleaning/drying the start switch similar problem i had with the divvy Thumbs Up
woll
PostPosted: 19:20 - 24 Mar 2013    Post subject: Reply with quote
Sounds just like my mates old sv when the battery died. After a lot of pratting around it would bump start. If he held the start button the dials would do strange things. And it wouldn't run for very long at all.
The last post was made 13 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 76.9 Kb
