Woodstove Paint + Exhausts?
Azmodeus
PostPosted: 21:00 - 20 Nov 2004    Post subject: Woodstove Paint + Exhausts? Reply with quote
Ive just bought myself a spray can of Woodstove paint - black.
The idea being that it should be heat resistant enough to be sprayed on my exhaust end and pipe, as the new cover I got doesnt infact cover it completely, which shows up the brown flakey bits even more.
I dont want to be going down the road, and the damn thing catches fire! Mr. Green
Has anyone tried this before?
mr jamez
PostPosted: 21:03 - 20 Nov 2004    Post subject: Reply with quote
Loads of people have done it, works fine as long as it is the correct type of paint. You can use something like BBQ paint or there are specific products for use on exhausts/exhaust manifolds. As long as the paint is comfortable at the temperatures that the surface will reach then it is fine Smile
instigator
PostPosted: 21:07 - 20 Nov 2004    Post subject: Reply with quote
Should work well, yeah.
I used very high temperature paint from gears4bikes.com Worked quite well although took a whole day to do
Azmodeus
PostPosted: 21:17 - 20 Nov 2004    Post subject: Reply with quote
Oh, thats good to hear.
I was near Focus (went to go buy some winter biking gloves) and thought I would pop in and see how much a can was (and if they did it in sprays)
Just under £6 incase you were wondering Smile
Visitor Q
$25 whore
PostPosted: 00:50 - 21 Nov 2004    Post subject: Reply with quote
a can of proper VHT costs about that too. And yes /that/ works bloody well as i know from experience. Although it doenst overly protect much if its already rusting. But it does make it pretty
Azmodeus
PostPosted: 15:45 - 24 Nov 2004    Post subject: Reply with quote
Ok, I had some free time today, so thought I would go do it.
It looks good, - 3hrs to fully dry.
Ill let you know if I come home one day with my leg in flames cause it wasnt heat resistant Razz
425c I think it can stand. Should be enough, shouldnt it?
stryker
PostPosted: 16:02 - 24 Nov 2004    Post subject: Reply with quote
Don't you mean https://www.gear4bikes.com ?
Now what?
NSR125-Kid-UK
Attention Whore
PostPosted: 16:06 - 24 Nov 2004    Post subject: Reply with quote
Not sure. I read in another magazine that the exhaust gases that power turbos can easily reach 1000C. Should be cool though - i've sprayed my exhaust and had no problems Smile.
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
MissFickle
PostPosted: 17:21 - 24 Nov 2004    Post subject: Reply with quote
I wouldnt spray mine.. Confused
PostPosted: 18:05 - 24 Nov 2004    Post subject: Reply with quote
You can use it fine if it is designed for cast iron wood stoves. What sort of temperature does it take to make 1/4" thick cast iron glow cherry red? That is how hot it will cope with.
Stinks a bit as it heat cures the first couple of times you use it though, this will pass.
The last post was made 21 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 65.08 Kb
