Which is the bleed nipple?
JiveBunny This post is not being displayed because the poster is banned. Unhide this post / all posts.
fatpies
PostPosted: 11:28 - 22 Mar 2013    Post subject: Reply with quote
Nooo!
The bleed nipple is where the plastic tube is attached to in the picture. It should be an 8 spanner, the ring spanner should fit on the base of the bleed nipple where the tube happens to be.
Its a case of pump 5-10 times, press hold, undo bleed nipple. Give it a couple secs. Redo the bleed nipple. Pump etc repeat.
Top up master cylinder as the level will go down to replace the fluid lost via the nipple.
You might want to put the end of the tube into a cup of brake fluid to prevent it from sucking up air from there.
PostPosted: 11:49 - 22 Mar 2013    Post subject: Reply with quote
Thats quite a bad nick disk for an 11 plate buddy.
Nick_Giles
PostPosted: 11:58 - 22 Mar 2013    Post subject: Reply with quote
Is that a fracture in the disk (bottom left) ???
Hope so.! - Could lead to the death of the trolling OP Twisted Evil
I suspect this like ALL his other posts has been made to provoke a reaction and these images are nothing more than lifted from 'google images' for this purpose alone. Thumbs Up
Nick
Alpha-9
PostPosted: 12:05 - 22 Mar 2013    Post subject: Reply with quote
But don't worry, it's not chinese it's korean. Did you not see it before? It's fucked and he's still using it, asking for trouble imo
Had a go at bleeding my brakes myself, problem is if I hold the lever down, then undo the nipple, the lever can then be squeezed more and fires fluid out the nipple?
Fzr-600 1999
RyanTZR125
PostPosted: 12:08 - 22 Mar 2013    Post subject: Reply with quote
https://i3.photobucket.com/albums/y87/NitroCowBoy/ouch-7_zpsaec3a2c1.jpg
1980 Honda H100A, Cafe racer. (SOLD)
1998 Yamaha TZR 125 4HX.
1999 Yamaha R6 YZF
Tristan.
PostPosted: 12:12 - 22 Mar 2013    Post subject: Re: Which is the bleed nipple? Reply with quote
JiveBunny wrote:
I need a quick crash guide how to bleed rear brake I have to ride to work in heavy snow at two and need a rear working break.
https://oi48.tinypic.com/35kqrrt.jpg
Is it the banjo bolt I open?
Open banjo bolt, push brake pedal, close and release brake pedal?
That is what it says on a how to video but I do not know which is the bleed nipple bolt.
What a shot design. Did your original banjo bolt have a nipple integrated into it. As that will be a right cunt to bleed.
devojunior
PostPosted: 12:48 - 22 Mar 2013    Post subject: Reply with quote
the full pads are not even touching the disc. is that the back end of a hyosung or another chinease bike ?
neil.
PostPosted: 12:54 - 22 Mar 2013    Post subject: Re: Which is the bleed nipple? Reply with quote
JiveBunny wrote:
I need a quick crash guide....
In that case just leave it be. You'll crash quickly. Smile
PostPosted: 12:55 - 22 Mar 2013    Post subject: Reply with quote
That is a peculiar design. Still, as long as there's not too much air in the system, it should be possible to get it out.
You may find that you have to crack the banjo bolt a little if there's air trapped up there, but leave that as a last resort.
What you'll want to do is to loop that tube over so that it goes upwards after leaving the nipple. This will create a column of brake fluid that will stop air being drawn back in when you let off the pedal - that way there's less need to keep opening and tightening it up.
You can actually just renew the fluid by letting it run out this way, topping it up at the reservoir as it drains, but to get air out you are going to have to pump it out under pressure.
Be patient and determined (I know, I know) it can be a real sod to get all the air out of the system.
https://rogerborg.dnsd.me/bleed-nipple.jpg
PostPosted: 13:05 - 22 Mar 2013    Post subject: Reply with quote
Have you actually got washers where the brake line connects?
PostPosted: 13:25 - 22 Mar 2013    Post subject: Reply with quote
JiveBunny wrote:
Some brake fluid came out of the banjo bolt is this normal?
See my last post.
jeddy11
If fluid is coming out of your banjo bolt and you havent loosened it then its leaking and you need to tighten it / get a new washer etc.
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
PostPosted: 13:35 - 22 Mar 2013    Post subject: Reply with quote
Both new washers?
One between banjo > hose and then hose > caliper.
andym
PostPosted: 13:46 - 22 Mar 2013    Post subject: Reply with quote
https://www.burningshadow.dk/Galleries/Facepalm/Facepalm3.jpg
Alpha-9
PostPosted: 14:02 - 22 Mar 2013    Post subject: Reply with quote
JiveBunny wrote:
I trust my skill will see me through.
https://img.playground.ru/images/2/5/oh_you.jpg
Fzr-600 1999
PostPosted: 14:19 - 22 Mar 2013    Post subject: Reply with quote
If you've got fluid coming out around the banjo, then air will be going in there. Don't rely on that brake pedal as anything other than an extended foot peg.
PostPosted: 14:23 - 22 Mar 2013    Post subject: Reply with quote
Yup, you need one per side.
https://i291.photobucket.com/albums/ll294/VeX86BirD/Master%20Cylinder/Step-6_Remove_MC_Banjo_Bolt.jpg
andym
PostPosted: 14:26 - 22 Mar 2013    Post subject: Reply with quote
I can't wait to see the 'skill' when you are lying in a broken crumpled heap somewhere because of your stupidity.
Honestly, Jivebunny you are a complete moron.... if you were closer I would come round and first give you a bloody good slap then fix your heap of shit as your 'skill'/luck will let you down one day when you least expect it.
The last post was made 12 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.56 - MySQL Queries: 13 - Page Size: 129.79 Kb
