Exhaust stud holes stripped on 250n
pepperami
PostPosted: 22:09 - 21 Mar 2013    Post subject: Exhaust stud holes stripped on 250n Reply with quote
I`m starting on the exhaust of my Superdream 250n ready for it`s new(er) exhaust coming soon.
So after a soaking of Plus-gas for the last couple of days, I finally got some movement from the studs.
After much gentle/slow/steady easing, all four studs are out
However every silver cloud has a dark lining.
On inspection of the studs, it is clear they have never ever been out of the engine and were very corroded.
Also two of them were stripped!
So my question is : what is the remedy?
Is there a next size up I can put in after I have cut a new thread?
Will I need to get the holes Heli-coiled.
Is there enough meat for me to drill a bit deeper and put in some longer studs of the same diamiter.
Your advice is much needed
Many thanks oh mighty BCF
Serendipity
PostPosted: 01:04 - 22 Mar 2013    Post subject: Reply with quote
I'd vote helicoil.
It worked for me on both RXS100: https://www.bikechatforums.com/viewtopic.php?t=149709
...and CBR600.
Cheers.
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
Ariel Badger
PostPosted: 11:46 - 22 Mar 2013    Post subject: Reply with quote
Have you tried running the correct tap dowm the stripped holes. sometimes there is enough metal to form a new thread. If you have a lathe you could make up new studs with a larger diam thread on the one end and drill and tap out the head otherwise it is a thread insert like Helicoil (which I hate) and in either case use plenty of copper grease
stonesie
PostPosted: 13:53 - 22 Mar 2013    Post subject: Reply with quote
Time sert is much better than helecoil but to buy a DIY kit is expensive, a local engineering shop might do them.
https://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313&_nkw=time+sert+kit&_sacat=0&_from=R40
pepperami
PostPosted: 19:39 - 22 Mar 2013    Post subject: Reply with quote
Thank you chaps.
Those inserts look interesting?
There might not be enough metal there to cut another thread/repair the thread for the standard bolts/studs.
The standard studs are 6 by 1.0 .
I have a 7 by 1.0 tap, so I am thinking about cutting a new thread and using the next size up bolt.
I seek your thoughts oh mighty BCF, any potential problems doing that?
I can always revert to Heli-coils ?
The last post was made 13 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 44.77 Kb
