Pre mix ratio on a derbi drd evo
Scandy flick
PostPosted: 13:28 - 24 Mar 2013    Post subject: Pre mix ratio on a derbi drd evo Reply with quote
Hi after derestricting my drd evo and uping the jet should i increase the pre mix auto lube to add more 2 stroke oil? Thanks Very Happy
YBR Ric
PostPosted: 10:57 - 25 Mar 2013    Post subject: Reply with quote
No. The bigger main jet you've fitted to your two stroke will allow more oil through just as it will allow more fuel.
There is no need to alter the fuel/oil ratio, adding more oil will only reduce the fuel octane rating and reducing it will probably result in other problems.
uberkron
PostPosted: 21:31 - 25 Mar 2013    Post subject: Reply with quote
The oil pump gives approximately 50:1. Its better than pre mix as oil is added even on trailing throttle. I run autolube, but fill the tank with 100:1. I like smoky two strokes that foul plugs and seize with carbon.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
uberkron
PostPosted: 21:32 - 25 Mar 2013    Post subject: Reply with quote
The last post was made 13 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 48.78 Kb
