Spanner wielders of BCF...lend me your ears!!
mudcow007
PostPosted: 15:06 - 25 Mar 2013    Post subject: Spanner wielders of BCF...lend me your ears!! Reply with quote
alright boyo's
im trying to replace a seal on my CG genny plate thingy
https://i25.photobucket.com/albums/c81/mudcow007/20130316_170127_zps6de74261.jpg
(big round black thing on this pic)
any ideas how i can replace it (im guessing the new one will have to be driven in) without damaging the strator behind it?
to remove the old one can i just screw a screw into it an yank it out?
gracias
27cows
PostPosted: 15:09 - 25 Mar 2013    Post subject: Reply with quote
You should be able to carefully push it into place with your thumbs. It's not like a bearing, there's no great resistance, especially if you make sure the housing is greased before putting it in.
A large socket about the same size as the OD of the seal could be used as a drift, if it was necessary. But seals are easily damaged and you'd need to be very careful.
PostPosted: 15:42 - 25 Mar 2013    Post subject: Reply with quote
I'd probably just ping/lever the old one out with a big screwdriver then push the new one in with my thumbs.
If it won't push in, use the old one on top of it as a driver, or a bit of plastic water pipe the same size as the OD of the seal.
mudcow007
PostPosted: 15:44 - 25 Mar 2013    Post subject: Reply with quote
cheers one an all Karma accordingly
as you all said the old one just pinged out with a screwdriver an the new one just slipped in after being liberally greased
just hope the swine stops leaking now
thanks
Raffles
PostPosted: 17:44 - 25 Mar 2013    Post subject: Reply with quote
Did you change the large ''O'' ring as well? If not then it would probably be a good idea to do so whilst you have everything apart.
mudcow007
PostPosted: 19:37 - 25 Mar 2013    Post subject: Reply with quote
God fecking dammit bastard fecking GAHAHAHAHAHAH
its still fooking leaking after replacing both seals
i'm getting fed up of this "bomb proof" bike Sad
anyone any ideas where it could be leaking from??
it should make a pretty bonfire......
radicalrabit
PostPosted: 21:24 - 25 Mar 2013    Post subject: Reply with quote
is there a right way and wrong way to put these in ?
VF1000 F2F, BLACKBIRD with carbs, 2nd VF1000F2F just need somewhere to go now..
27cows
PostPosted: 21:29 - 25 Mar 2013    Post subject: Reply with quote
How bad a leak is it? Is it just as bad as it was before?
mudcow007
PostPosted: 21:32 - 25 Mar 2013    Post subject: Reply with quote
well...i refitted everything, refilled with oil.
kicked her over a few times - wouldn't start (i'm guessing because of the cold) an i noticed a dribble of oil through the flywheel
so im guessing if/ when it fires up the leak would get pretty messy
i will whip the flywheel off again an try to figure out where its leaking from
as radicalrabit says....is there a correct an wrong way for a seal to be fitted?
i fitted the new one as per the old one with the flat side facing out with the spring inside
Raffles
PostPosted: 22:14 - 25 Mar 2013    Post subject: Reply with quote
The oil seal has been installed the wrong way around.
The ''spring'' side should be facing inwards towards the crank.
mudcow007
PostPosted: 09:01 - 26 Mar 2013    Post subject: Reply with quote
Pants!
really>?
so the seal in the pic above is incorrectly fitted too?
i will take it out tonight an try an switch it around
thanks raffles
Raffles
PostPosted: 10:05 - 26 Mar 2013    Post subject: Reply with quote
If you scroll down to Chapter 6, page no. 94 then you will see a picture of how the oil seal should be mounted within the stator plate:-
https://cpi.shs.net.pl/files/Poradnik%20warsztatowy%20Honda%20CG125%20(Workshop%20Manual).pdf
BTW Unless the oil seal that you have already installed is a very loose fit then you will probably knacker it during removal.
27cows
PostPosted: 12:42 - 26 Mar 2013    Post subject: Reply with quote
You can normally remove seals without damage if you're careful, especially given that it's only just gone in. If I had a quid for every time I've reused old seals, I would literally have enough money to buy a brand new seal Laughing
mudcow007
PostPosted: 13:31 - 26 Mar 2013    Post subject: Reply with quote
the seal i'm replacing was fitted by a garage but was still leaking when i got it back so i just copied how they had fitted there pah!
i know what i'm doing tonight
also, kinda have a bit of self doubt now, is it possible to fit the flywheel in the wrong position?
it has a woodruff (i think its called) key but i suppose ti could still be off?
27cows
PostPosted: 14:15 - 26 Mar 2013    Post subject: Reply with quote
You can't really put the flywheel on wrong. Or if you did, the bike wouldn't spark. No, looks like the issue is the seal being round the wrong way, hence the very large amount of oil leaking (normally you'd only get a small bit of seepage even under heavy use, if the seal had just worn normally).
Never trust anyone but yourself to do work. That's my motto.
johnsmith222
PostPosted: 17:59 - 26 Mar 2013    Post subject: Reply with quote
Agreed. It's better to know what has been done to your own bike and also where the blame lies when it all goes wrong.
A mechanic has everyones bikes to worry about. You just have your own. Plus it's not as if it's the mechanic that snuffs it if you crash because it's been done wrong.
bikenut
PostPosted: 15:20 - 28 Mar 2013    Post subject: Reply with quote
you sure a garage fitted it??
mudcow007
PostPosted: 16:57 - 28 Mar 2013    Post subject: Reply with quote
Yap...at the Aprilia dealer in Wallesey
mudcow007
PostPosted: 18:53 - 29 Mar 2013    Post subject: Reply with quote
i think i may have found my leak....
after running the bike last night idling for about 10mins i noticed there was a bit of oil on the o-ring on the selector shaft (i think its called - yellow pointer in pic)
https://i25.photobucket.com/albums/c81/mudcow007/20130327_220114_zps7c707aa3.jpg
i think i will see how bad it leaks, as it looks a ball ache to start removing that
The last post was made 13 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.11 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 105.21 Kb
