Stupid newbie question
Rob1970
PostPosted: 15:45 - 25 Mar 2013    Post subject: Stupid newbie question Reply with quote
When people are removing rear wheel/adjusting chain etc do they use a socket, ring spanner or torque wrench to undo and do up the axle bolts
Reason i ask is that i've used the little stubby ring spanners in my toolkit but they are obviosuly hard work and I don't have anything 27mm or 22mm in my tool kit so need to buy a workshop tool to do the job
PostPosted: 15:48 - 25 Mar 2013    Post subject: Re: Stupid newbie question Reply with quote
Yes, I do use those.
Smile
I'd probably use a socket on normal ratchet - however very occasionally have used an torque wrench.
Probably have a ring spanner the other side.
If ring spanner's are to hand, I'll may use them on both sides.
Oh and to be pedantic - it's generally referred to as a spindle rather than an axle Smile.
Rob1970
PostPosted: 15:58 - 25 Mar 2013    Post subject: Reply with quote
Ok - I'll get a big hefty ring spanner then and guess the torque!
CarlosCBR
PostPosted: 16:02 - 25 Mar 2013    Post subject: Reply with quote
I normally use a ring spanner one side and a socket/wrench on the nut side, then torque wrench when doing it back up again.
PostPosted: 16:03 - 25 Mar 2013    Post subject: Reply with quote
If you're on a budget and buying a spanner, I'd recommend this set:
www.ebay.co.uk/itm/120946134532
Compared to the cost of a single spanner, much better value and should cover 'much everyhing on a bike.
I have got the above spanner set and am happy with it. I haven't got the below socket set, but have had a similar one and again happy with it:
www.ebay.co.uk/itm/190682579772
Note that the extension bar can be used as a t-bar 1/2" wrench, meaning you can use your 27mm and 22mm at the same time.
Islander
PostPosted: 16:08 - 25 Mar 2013    Post subject: Reply with quote
You're unlikely to shear the spindle or strip the thread that way so go for it - it needs to be tight!
Walloper
PostPosted: 16:37 - 25 Mar 2013    Post subject: Reply with quote
To Guess Motorcycle Axle/Spindle Torque: Tighten nuts until the axle breaks then back it off 1/3 of a turn.
Jest ^^^
The last post was made 13 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 53.03 Kb
