Charging mobile from a motorbike.
Eddie Hitler
PostPosted: 22:12 - 25 Mar 2013    Post subject: Charging mobile from a motorbike. Reply with quote
Need some advice regarding this, heading over to Europe in the next few weeks for a short tour. Need a cheap charger to charge my phone, if possible whilst on the move.
Checked Google, did some searching on here but all that I can find is some £25 jobs on eBay. Surely there's a cheaper way to do this? Or should I suck up it up and splurge the money?
gfrancisdev
PostPosted: 22:21 - 25 Mar 2013    Post subject: Reply with quote
Wire a 12V car socket into the bike and use whatever car chargers are needed (usually just a usb converter+cables you probably have lying about)
if it's only going to be phones/etc you can get away with wiring it to the ignition/rear light line, otherwise you'll want to put in a relay and fuse etc
pretty simple to do, shouldn't cost more than 20 odd for wire+socket+connectors etc
raesewell
PostPosted: 22:34 - 25 Mar 2013    Post subject: Reply with quote
you need one of these
https://www.ebay.co.uk/itm/DC-DC-Converter-Regulator-12V-Step-down-to-5V-3A-Power-Supply-Module-Waterproof-/300880724421?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item460de381c5
ws4936
PostPosted: 22:44 - 25 Mar 2013    Post subject: Reply with quote
Either wire in one of these, has to have the waterproof cover...or one of these, which are very good. They turn off after your mobile reaches 100% charge. Or do both, then your laughing.
If everything seems under control, you're just not going fast enough.
doggone
PostPosted: 22:49 - 25 Mar 2013    Post subject: Reply with quote
The 5V USB charging is now becoming so universal it's high time most vehicles had one or more fitted as standard.
J.M.
PostPosted: 23:32 - 25 Mar 2013    Post subject: Reply with quote
Absolute cheapest, bodge-job, way to do it:
- Purchase relay, wire relay in (not strictly needed, but do it..)
- Purchase in-car charger
- Crack open in car charger, de-solder terminals, solder on longer wires
- Attach these new longer wires to relay
- Wrap in tape
- Enjoy
2004 R1 & 2018 XSR900
PostPosted: 23:44 - 25 Mar 2013    Post subject: Reply with quote
Not nearly bodgy enough - get usb car charger and two random bits of wire. Wrap wire around an already-relayed live with a bit of juice and around tape on to terminals.
Or do the same with a socket straight to the battery.
Casper
PostPosted: 01:22 - 26 Mar 2013    Post subject: Reply with quote
I use this
https://www.ebay.co.uk/itm/12v-Universal-Cigarette-Socket-Lighter-Accessory-/260811741915?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cb9975adb
And
https://www.ebay.co.uk/itm/Mini-DC-USB-2-Port-Output-Car-Charger-Adapter-12V-24V-For-iPhone-5-iPad-Mini-/350727486205?pt=UK_MP3_Player_Accessories_Chargers_Docks&hash=item51a8fcbafd
Wired into brake light switch but direct will be fine as you take the phone with you when away from bike. £5.70, how cheap can it be?
Dave_R
PostPosted: 01:55 - 26 Mar 2013    Post subject: Reply with quote
I say spend about a tenner;
Fuse piggy back - £4
Lighter socket (pre wired) - £4
Lighter socket USB charger - £2
Find a sub-circuit fuse that's powered on with your bike and piggy back off it, no need for relays or 'regulators'.
Eddie Hitler
PostPosted: 10:39 - 26 Mar 2013    Post subject: Reply with quote
Brilliant, didn't think of wiring in a car cigarette lighter, that's the option I'll go for I think. Plenty of good ideas. Thumbs Up
EazyDuz
PostPosted: 11:44 - 26 Mar 2013    Post subject: Reply with quote
I did an even more bodge job.
Wired a fused cig lighter socket direct to battery. Means i can plug a phone/tablet in for example, and leave it on the bike for a couple of hours...
I had heated grips draining my battery over a few weeks and even they didnt drain it enough to not start the bike, so as long as you dont go potato and forget you have your phone charging on it, you shouldnt have an issue.
I just have it cable tied by the handlebars so i can charge the 5 year old satnav while on the move (its so old it has about half an hour charge left in it) Shocked
covent.gardens
World Clap Champion
PostPosted: 12:07 - 26 Mar 2013    Post subject: Reply with quote
I did what JM did, only cost about £3.
Then I bought a ctek battery charger, comes with a lead you attach permanently to the battery. Other end of the lead, has a plug, you can attach the charger to, or another ctek accessory, and they do a 12v cig lighter accessory (ready fused). I use that now, with a 12v-cig-lighter-to-USB converter, I keep it under the seat. It only really cost me £10 for the accessories as I needed the charger anyway.
No messing with wiring, this is plug and play
kernow24
PostPosted: 13:17 - 26 Mar 2013    Post subject: Reply with quote
https://www.ebay.co.uk/itm/DC-Converter-Buck-Module-12V-convert-to-5V-usb-output-power-adapter-/330761530133?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4d02ec6b15
I use one of those, same as someone posted above, but it has a usb plug attached already. Although they were a lot cheaper before, but I can't seem to find the seller, they were around £2 - £3
Chuck a couple of ring terminals on the end, attach directly to the battery and the jobs a goodun.
Can plug any usb cable in to it, although I've used one of those multi ended cables to enable a charge up a multitude of things.
c-m
PostPosted: 14:29 - 26 Mar 2013    Post subject: Reply with quote
Don't bother with a relay.
Otherwise you'll not be able to charge the phone with the bike turned off. Like say when you're at a campsite for a day or so.
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
PostPosted: 14:33 - 26 Mar 2013    Post subject: Reply with quote
https://i48.photobucket.com/albums/f216/stinkwheel/rbr/DSCN0793.png
Wobbling Dog
PostPosted: 20:59 - 26 Mar 2013    Post subject: Reply with quote
half expected to see a candlestick telephone in there !
Casper
PostPosted: 23:45 - 26 Mar 2013    Post subject: Reply with quote
That is what I want but cant find a UK seller.
kernow24
PostPosted: 00:32 - 27 Mar 2013    Post subject: Reply with quote
cheaper ones here...
https://www.ebay.co.uk/sch/i.html?_nkw=12V+To+5V+3A+15w+Power+DC-DC&_sacat=0&_odkw=12V+To+5V+3A+15w+Power+DC-DC+Converters&_sop=15&_osacat=0&_from=R40
Chinese sellers are fine, always use them on eBay, things usually take about a week to arrive.
Casper
PostPosted: 00:11 - 28 Mar 2013    Post subject: Reply with quote
So have you bought from one of those? Its only a few quid but being Scottish I hate to get ripped of from 1p never mind a quid Laughing
The last post was made 12 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 103.35 Kb
