| 27cows |
 27cows World Chat Champion
 Posted: 18:00 - 27 Mar 2013 Post subject: RXS100 suddenly afflicted with bizarre engine woes |
OK, virtually every part of my old girl has done ridiculously high mileage. Yes, everything is bodged. Yes, my motor is a collection of less than perfect bits and bobbles. But normally she'll soldier on reliably no matter what.
I had a ring go on me for the first time ever on this bike a couple of weeks ago. Top end had done a ludicrously high mileage so it was to be expected. But coming home I suddenly had horrific metallic noises coming out of the bottom end. Seemed too loud for it to be the missing ring peg I discovered when giving top end a look over. No sign of shrapnel damage in the combustion chamber. Bottom ring had cracked but no pieces were missing. Replaced top end with slightly less worn out one. No further horrific noises...but something had made that racket.
Shortly after I had a clutch issue. With lever pulled in, bike started creeping forward. Couldn't be adjusted to behave. Whipped cover off - no sign of damage. But tightening up the clutch centre nut, the centre itself seems extremely reluctant to turn freely. Double checked that I hadn't missed something. Still the same. Tried a different centre and this one was OK. Clutch worked as normal...only now I had another bloody noise - an odd rhythmic sound. Not metallic. Kind of dull throb/knock/heavy tapping. Not what you'd get from big end, for example.
Now I've acquired an quite unpleasant rumble. Checked mains - fine. Which is to say, no movement at flywheel. I thought I knew these motors like the back of my hand but clearly not.
Performance is about the same as ever. A fair way from what you get with a sweet RXS motor, but still able to do 65 without any great trouble. Only now I'm getting duh-duh-duh-duh....horrible rumble FFS, am I going to have to gather assorted bits and make a bottom end to replace this one? Am I missing something stupidly obvious? Is the motor conspiring with the buggered frame to tell me that the party is finally over after 23 years? ____________________ The RXS100: vehicle of choice for Chuck Norris |
| SQL |
 SQL World Chat Champion
 Posted: 18:18 - 27 Mar 2013 Post subject: Re: RXS100 suddenly afflicted with bizarre engine woes |
Might be time to take "Ole Yella" out back.  |
| 27cows |
 Posted: 20:06 - 27 Mar 2013 Post subject: Re: RXS100 suddenly afflicted with bizarre engine woes |
| SQL wrote: |
Hopefully not But these issues really are odd. It's like the motor has been contaminated with CBS (Chinese bike syndrome). Have been rooting through assorted boxes of old shite in the garage - I have two sets of crankcases, three gearboxes (one of which doesn't hold 5th), two cranks (one of which is definitely buggered) and one brand new set of main bearings that were given to me years ago by some kind soul.
I think I can knock up another bottom end. But it's extremely irritating to have these issues. Everything looks fine. But the odd bloody noises say otherwise. ____________________ The RXS100: vehicle of choice for Chuck Norris |
| cb1rocket |
 cb1rocket World Chat Champion
| cb1rocket |
| 27cows |
| 27cows |
| bladerunner |
| 27cows |
 Posted: 21:16 - 27 Mar 2013 Post subject: |
No balancer in the RXS. Never broken a clutch pushrod either. In fact it's possible I'm still using the original after 417,000 miles - I certainly have never bought a new one.
I guess my old relic does have a relatively easy life. I try not to abuse the motor (not always easy on a bike that slow ). I ride with the long life of the engine components in mind.
I've had assorted LCs over the years - the opposite of the RXS really. But immensely good fun. Especially the 350.
The more I think about it, the more I think it's right side mains gone. Trouble is, these motors are so tough and reliable that you sometimes forget that bits do eventually wear out. Having said that, the original mains went to over 300,000 miles and were still fine when I replaced them while doing a rebuild to put a new crank in. ____________________ The RXS100: vehicle of choice for Chuck Norris |
| bladerunner |
| UnspeedySam |
 UnspeedySam World Chat Champion
| 27cows |
 Posted: 14:12 - 28 Mar 2013 Post subject: |
It's not one of the mains but the one behind the clutch. Hence the symptoms not being in line with those of failing main bearings. That bearing is part of the original motor and has done approximately 385,000 miles. Which I have to say is a pretty reasonable life The clutch had been able to move up and down about 2mm, which I guess caused both the rhythmic thump and horrible rumble.
Have replaced all the bearings except the mains with ones out of an old pair of crankcases that have been sitting on the shelf for years. Got this paranoid feeling I've put the gearbox together wrong But I think it's impossible to close the cases if that's actually the case. At least, I hope so
Will hopefully get the motor back in over Easter. Having to use the fat Bandit as commuter/runabout. It's bloody useless through heavy traffic. Hoping to have the DT125R sorted soon too and that can be commuter back up to the RXS, assuming the latter runs well enough to go back into service. ____________________ The RXS100: vehicle of choice for Chuck Norris |
| UnspeedySam |
 Posted: 15:51 - 28 Mar 2013 Post subject: |
| 27cows wrote: | It's not one of the mains but the one behind the clutch. Hence the symptoms not being in line with those of failing main bearings. That bearing is part of the original motor and has done approximately 385,000 miles. Which I have to say is a pretty reasonable life  The clutch had been able to move up and down about 2mm, which I guess caused both the rhythmic thump and horrible rumble.
Will hopefully get the motor back in over Easter. Having to use the fat Bandit as commuter/runabout. It's bloody useless through heavy traffic. Hoping to have the DT125R sorted soon too and that can be commuter back up to the RXS, assuming the latter runs well enough to go back into service. |
You don't need a backup if you've got an RXS At least if you've got a spare engine lying around if stuff like this happens  ____________________ Riding: BMW R1150RT `02 bought mildly crashed
Gone: ZZR600 '00, TRX850 '97, RXS100 '93, JS125-6B '07, BMW R1100RS '93, Kawasaki ZX-6R-J2 '01, Honda Bros NT400 NC25 '88 |
| 27cows |
| Ariel Badger |
 Ariel Badger Super Spammer
The last post was made 13 years, 234 days ago. Instead of replying here, would creating a new thread be more useful? |
