Little help please
Going2fast
PostPosted: 15:48 - 21 Nov 2004    Post subject: Little help please Reply with quote
Hey there,
I'm having a little problem with my bike starting, its an 95' RVF400.
The bike has only just been delievered, only been a few days now so everything should be working correctly i say.
I started her up two days ago and after yes a little work she started up, it was freezing cold mind you. Got her running for a good 20minutes, but only stand still (no lience yet Sad )
Came to it today, would it start? would it &*^%. I mean its a beautiful thing and she just wont start Crying or Very sad I was trying for ages so now i think i may have flattened the battery Sad
Any advice? I mean i know its cold out there now but still i've known older bikes to start up first time in colder temperatures.
A Sad Andy Crying or Very sad
Passed My Test 15/03/05 Very Happy Very Happy
BikePics Profile ||| 96' RVF 400 ||| 01' CBR 600 F Sport ||| 2009 Yamaha YZF-R6 Delivered 23/06/09
/-\ndy
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
Frost
PostPosted: 01:45 - 22 Nov 2004    Post subject: Reply with quote
Press the started button, what happens?
Does it turn the engine over?
If so try and bump start it. (Push it forwards to get some speed up, let the clutch out when its in gear and press the starter)
If that doesnt work check your spark plugs arnt clogged/fouled and that they are actualy sparking strong ans consistent (ground the metal of the plug out on something then press the starter and it should spark).
If the engine doesnt turn over then your battery is flat. this might be due to lack of use, you thrashing the starter motor, or an alarm draining the battery.
Good luck Thumbs Up
Hex
Party Boy
PostPosted: 10:28 - 22 Nov 2004    Post subject: Reply with quote
Erm since when do you press the start button when bump starting?
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
sickpup
Old Timer
PostPosted: 11:55 - 22 Nov 2004    Post subject: Reply with quote
Is it restricted?
tatters
Exxon Valdez
PostPosted: 12:04 - 22 Nov 2004    Post subject: Reply with quote
the easyest way for you to bump start it, is to put the bike in second gear sit on the bike hold the clutch in and get your dad to push the bike up to speed then let the clutch out and pull it back in when you feel the engine fire up.
Claud 14.7 to 1
PostPosted: 13:00 - 22 Nov 2004    Post subject: Reply with quote
I used to use second for jump-starting. It was ok, but now use 1st and dump the clutch. This works more often on mine, and you don't have to go as fast.
Chris89 gave me that tip.
So rolling down the road, (with ignition on), select first, then dump the clutch. Then you can either pull the clutch back in and rev it (to keep it alive). Or just ride away normally. Smile Cool
Mine is a bitch to start somedays. Battery is nearly always "low" as I have no charger. Battery may be on the way out on mine. I can't test it till I'm back at my house.
You'll always hear me coming back, because I'll have it at 5k - 6k rpm with no electrics on, just to give it that bit more charge, for the next time I start it.
Damn bike. Cool
Going2fast
PostPosted: 17:57 - 22 Nov 2004    Post subject: Reply with quote
Cheers all for the replies, Need to check the main fuse now as i'm backfiring which is not good. If not, the wonders of having a warrently will play its part hehe.
Cheers for replies again Very Happy Thumbs Up
Andy
/-\ndy
Guest
PostPosted: 18:58 - 22 Nov 2004    Post subject: Reply with quote
No need to check the fuse if it's back-firing, that's probably due to the pipes being loaded with un-burnt fuel.
I'd suggest taking the plugs out and cleaning then as they'll more than likely be soaked but it's under warranty and I bet it's a sod to get at them on that bike.
Leave it to stand for a day while you charge the battery up, thenuse plenty of choke and no throttle till you hear the engine start to catch.
Don't bother running it on the stand every few days, you can do more harm than good. Leave it well covered up until the time you can use it properly - if that's going to be ages take the battery off and store it indoors and charge it just before you're going to use the bike.
Do you know the correct way to take the battery off?
Going2fast
PostPosted: 19:20 - 22 Nov 2004    Post subject: Reply with quote
Yeah i should be fine, i was thinking of just storing it till i can use it all the time.
Andy
/-\ndy
Claud 14.7 to 1
PostPosted: 19:42 - 22 Nov 2004    Post subject: Reply with quote
Next time you get it running warm it up for a minute of two then give it a nice handful of revs. Get some of that excess fuel burnt off.
Mine did back fire a lot. I traced it down simply to starting technique. Basically, now I let it turn over on or two times (only takes part of a second) before I add the throttle, (mine needs part throttle to get it started).
Initially I was adding the throttle a fraction too early, maybe even before the engine turned over, and that meant I was getting too much fuel in on the first turn/ few turn overs, then bang happens.
Too much choke and the same backfiring happens on mine. You will get used to the "starting technique".
You only need the slightest bit of throttle (if any, on some bikes, so the manual says) on the Hondas to get them started. As you know the throttle is quite sensitive, so you have to find the balance.
Of course your bike could be different...
When did it have the valve clearances checked/adjusted last? How many miles does it have?
Claud 14.7 to 1
PostPosted: 19:45 - 22 Nov 2004    Post subject: Reply with quote
Yes the plugs are utter bitches to get at, so I'm told.
They are hard enough to get to on mine Confused (and mine is an inline 4). Had to make up a tool to do them... Rolling Eyes
Going2fast
PostPosted: 21:54 - 22 Nov 2004    Post subject: Reply with quote
Only about a 2weeks ago i believe, I've been told the RVF stock battery is not very good, might get a heavy duty one or something. By the way checked the spark plugs and there alright. Going to give the battery a charge and see if she starts up, if not hello mr warrenty lol Wink
/-\ndy
tatters
Exxon Valdez
PostPosted: 21:57 - 22 Nov 2004    Post subject: Reply with quote
have heared that backfiring is common now and again on honda V4,s my VFR did it every other week.
Going2fast
PostPosted: 20:17 - 24 Nov 2004    Post subject: Reply with quote
Officially dead lol, going to the doctors soon Razz Thumbs Up
Then my beauty will be alive again YAY Thumbs Up
Andy
/-\ndy
Frost
PostPosted: 06:37 - 25 Nov 2004    Post subject: Reply with quote
The problem with bikes like the RVF is that they are highly prized and collectable. Most owners keep them stood for long periods of time only using them on special occasions. Others which are imported into the country come with problems, or have problems created by conversion to UK spec.
I suspect your bike has been stood for a fair while, and might have had unnoticed problems before that.
But being the wise man you are, you got yours from a dealer, so its all their problem! Very Happy
Hope they sort it all out for you so its ready and waiting for when you pass your test! Thumbs Up
Claud 14.7 to 1
PostPosted: 13:09 - 25 Nov 2004    Post subject: Reply with quote
Yeah and don't let them convince you to buy anymore stuff for it.
Any problems now, they sort out!
Going2fast
PostPosted: 18:53 - 25 Nov 2004    Post subject: Reply with quote
Yeah cheers, get this...
Rang them and they say sure bring it back to us and we'll fix it. Great, so i say when you going to collect it then? reply where you live, tell them oh its going to cost you Shocked Erm no its not going to cost me you sold me a bike which don't start, come pick it up and fix it or we go to trading standards Razz .
Anyways i hope she gets fixed soon.
Cheers for all advice and help given,
Andy
/-\ndy
Going2fast
PostPosted: 12:29 - 15 Dec 2004    Post subject: Reply with quote
UPDATE:
Was a problem to do with carb's or something, engine flooded. Not caused by me which is great Razz All fixed now, Thumbs Up
Should have her back for hopefully when i pass my test, if not early new year Thumbs Up Thumbs Up
Thanks for all advice and help given,
Andy
/-\ndy
The last post was made 21 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 108.19 Kb
