Broken Bolt/stud
zx81
PostPosted: 20:02 - 28 Mar 2013    Post subject: Broken Bolt/stud Reply with quote
Hi all
I'm wondering if any of you knowledgeable people can advise me on a small problem I have, I was removing the Exhaust from my bike .. there was one nut which was rounded I eventually got a socket on it and when I tried to remove it it completly sheared off Sad
now this "bolt comes from the engine and goes through the ring that holds on the exhaust and then the bolt goes onto the thread, now if it was just a bolt I could use a bolt extractor/ drill it out helicoil it.
but what do you do in this situation?
is this "bolt" / a threaded bar that is threaded into the engine or is it wielded onto the engine.
any advice would be appreciated.
cheers
zx
GSF650 (Bandit) -> GSR600
Benson_JV
PostPosted: 20:22 - 28 Mar 2013    Post subject: Reply with quote
I assume it's snapped flush with the head?
zx81
PostPosted: 20:35 - 28 Mar 2013    Post subject: Reply with quote
ahh Thanks Vincent .. been doing a bit of googling I see there are some tools for removing it if there are some threads showing.
Well I don't have power in the garage, but I have the nut in my pocket
there is 1 thread showing from the bolt, so there may be a little bit poking out, I'll need to check tomorrow when there's some daylight.
now assuming I get it out .. where would I get a replacment one from .. and what are they called .. or would I just use a bit of threaded bar cut to size ?
Benson_JV
PostPosted: 20:43 - 28 Mar 2013    Post subject: Reply with quote
I would use wemoto - they're listed as exhaust stud and exhaust stud nut.
I weld some mole grips onto the protruding tip and just twist them out - you could try soaking it in a penetrating oil (ideally for as long as you can) and getting a pair of moles on there.
Benson_JV
PostPosted: 21:01 - 28 Mar 2013    Post subject: Reply with quote
I understood it as only one thread on the snapped bit?
The last post was made 13 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 58.1 Kb
