Battery Chargers
MCW
PostPosted: 20:35 - 28 Mar 2013    Post subject: Battery Chargers Reply with quote
Sorry for silly question, but I know sod all about bike maintenance. Confused
Will an ordinary 12v car battery charger be ok for charging a bike battery?
End of silly question. Smile
andy_uk
PostPosted: 20:48 - 28 Mar 2013    Post subject: Reply with quote
I wouldn't recommend it being left on very long...the car ones can damage bike batteries.
If it has a low current/trickle charge setting you could use it to give the battery a boost but only if you really need to.
A proper bike battery charger is really the safest way to go.
Aprilia Classic 125, GS500E, ER5-A1, ER5-C4, ER6 & an XJ6 project frame...
MCW
PostPosted: 20:52 - 28 Mar 2013    Post subject: Reply with quote
Thanks Andy. Smile Now I don't feel that it is such a silly question.
Islander
PostPosted: 20:57 - 28 Mar 2013    Post subject: Reply with quote
You'll be fine using it for a couple of hours to get a charge into the battery just don't leave it on overnight. Thumbs Up
I recommend an Optimate 4 charger. They're ideal for bike batteries and will maintain them as well as charge them. They come with a flylead with ring connectors on one end that you permanently attach to the battery and a waterproof connector on the other than you hide behind a side panel or similar - this means that to charge the bike all you have to do is pull the connector out and plug the Optimate in. If the bike is left in a garage with power you can safely leave the charger connected - useful if it's laid up for any length of time. Thumbs Up
MCW
PostPosted: 21:02 - 28 Mar 2013    Post subject: Reply with quote
Thanks Islander, I will put it on my birthday list. x
doggone
PostPosted: 21:45 - 28 Mar 2013    Post subject: Reply with quote
The battery will often state a maximum charge rate on it - usually 1 amp for bikes, but even 10 would probably be OK for say 20-30 minutes for a quick boost.
I must say the bikes own alternator could potentially push out at least 20amps, not sure how that is not damaging, perhaps it is if your battery is really low.
Paivi
PostPosted: 22:00 - 28 Mar 2013    Post subject: Reply with quote
Go for CTEK XS3600, it wakes up a practically dead battery. I haven't used my Monster since last summer and put the battery on trickle charge y'day and the bike started first time a wee while ago.
The last post was made 13 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 51.46 Kb
