VooDoo Shango £160
SQL
PostPosted: 00:36 - 04 Apr 2013    Post subject: [FOR SALE] VooDoo Shango £160 Reply with quote
Selling my Dirt Jump bike (Pedal Bike) as I no longer use it.
Good Bits
The paint isn't bad a few chips here and there
The gearing is great it allows you to get up to speed quickly and hold it consistant for a single speed
The brakes are immense you can stoppie on a penny (Spec of them Below)
Bad Bits
Needs new grips to put it nicely the grips are horrid
Maybe a new seat as it has seen better days
Rear tyre is a little low
https://www.voodoobikes.co.uk/bikes/dirtbikes/shango
<!---Insert Specs Here ---->
Alloy Rims: Yes
Approximate Weight (KG): 15.5kg
Brake Type: Hydraulic Disc (F&R)
Chainset: Black tubular 3 piece
Forks: Full Chromoly with disc mount
Frame: Dirt Jump Full Chromoly
Frame Colour: White
Frame Material: Full Chromoly
Front Brake: Tektro Gemini Hydraulic disc 180mm rotor
Gears: Single Speed
Handle Bars: Riser 31.8mm
Headset: FSA Impact 1 1/8 Aheadset
Hubs: Formula 36 hole disc hub
Pedals: Wellgo BMX Type alloy black
Rear Brake: Tektro Gemini Hydraulic disc 180mm rotor
Rims: Double wall black rear and green front 36 hole disc rim
Saddle: VL-7100
Seatpost: Satori Pivotal SC
Stem: Dirt Jump
Tyres: Innova 26 x 2.5
Wheel Size: 26"
Tyre Size: 2.5"
Exact Frame Size: 13"
https://www.thebikelist.co.uk/images/models/Voodoo/2011/voodoo-shango/voodooshango_360_0101.jpg
^ Its this model (Stock photo)
Looking for around £230 ovno or maybe swap for something just try me
Pick up from Croydon
PM me Smile Mr. Green
The last post was made 13 years, 94 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Everything Else All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 29.33 Kb
