Fitting a temp guage?
Demonic69
The Pink Rhino
PostPosted: 17:43 - 23 Nov 2004    Post subject: Fitting a temp guage? Reply with quote
Can it be done to a bike that doesn't have one?
Back on a Blade. Just feels so right.
stevo123
PostPosted: 19:25 - 23 Nov 2004    Post subject: Reply with quote
Should be possible, when you buy a guage you should get a sender unit to go with it, this alters its internal resistance according to its surrounding temperature, ie coolant. The guage then works out the temp according to this and display it on the guage. Hardest bit will be where to mount the sender unit i would have thought-good idea is to fit the sender unit where the radiator plug is that you empty the coolant with?
binge
Emo Kiddy
PostPosted: 21:46 - 23 Nov 2004    Post subject: Reply with quote
I need a new thermostat for my speedy. My thermomiter is set in my cylinder... And its broken. Crying or Very sad At the bloody gague end. The pin fell out and wouldnt go back in and work so i just glued the pin pn place on about half temp (normal) and left it. Laughing
But now im keeping my scoot. Ive got the summer to get through, and without a termostat, its gna be worrying. Shocked
Ben..,.
Git
PostPosted: 22:07 - 23 Nov 2004    Post subject: Reply with quote
I once fitted a digital thermostat to a bike that had no temperature guage fitted as standard and had to find a place to stick a ptc type sensor. After searching for available water holes I ended up cutting a short length out of the top hose to fit a stainless t-piece.
The two straight arms took the hoses and the third arm I brazed in a thermopocket the closest size to the sensor available then I just covered the sensor in heat transfer paste and shoved it in the pocket worked very well.
binge
Emo Kiddy
PostPosted: 00:23 - 24 Nov 2004    Post subject: Reply with quote
I suppose the thermostat can go anywhere between the engine and the radiator. (leaving the engine). LOL!, call me mr state the obvious but you cant put the thermostat after the radiator. Smile
Ben...
mr.z
PostPosted: 03:32 - 24 Nov 2004    Post subject: Reply with quote
It can be done, fairly easyly...
There a aftermarket thermostats that either fit as the drain plug in the radiator, or another odie once mentioned to me where the thermo-coupleing goes between the gaps in the rad hose (held down with jubile clips)
Somewhere like m&p or busters... anywhere you can get aftermarket bits...
Did you want a digital one or dosen't it matter?
Git
PostPosted: 10:40 - 24 Nov 2004    Post subject: Reply with quote
I use these little gadgets for loads of stuff, coolant temperature, radiator fan control, oil temperature, ambient, refrigeration and even my house heating will get one when it gets a new boiler.
Pretty accurate and 12vdc supply also, loads of sensor variations a great toy. Not to everybodys taste though.
stryker
PostPosted: 12:09 - 24 Nov 2004    Post subject: Reply with quote
Ooh gadgets. How much and where from?
Now what?
binge
Emo Kiddy
PostPosted: 12:25 - 24 Nov 2004    Post subject: Reply with quote
Gee thats huge, Wink
I wouldnt want that on my scooter bars...
Im geting renthal bars, so Im after a small aftermarket fuel gague and a small after market thermostat. Ive already got a Speedo but I want to get a better quality because when it reaches 55 - 60 it just gets confused and stops...
Ben...
Git
PostPosted: 12:59 - 24 Nov 2004    Post subject: Reply with quote
It is a shade large for some but with a bit of handy work with a soldering iron the front panel/display can be removed so it is only 15mm or so thick, the rest of the lump can be mounted inside a panel somewhere and joined up with a bit of thin multicore, that lump houses a relay for fan control or whatever you wish to control, could even wire it up to control the temperature of your heated pants this time of year!
I get mine from.... van stock, but I am sure your local domestic refrigeration repair man will be able to get one if you know the model number, basic one relay version about 50notes.
Also seen them on ebay at times, search for digital thermostats or manufactures name, eliwell, lae, dixell to name a few but ebay tends to come with no instructions, I would be happy to mail instruction if the need arises or help with model selection.
For more suitable guages?
https://www.gower-oaks.co.uk/
https://www.spa-uk.co.uk/design/dualgauges.htm
binge
Emo Kiddy
PostPosted: 13:05 - 24 Nov 2004    Post subject: Reply with quote
Im not even fussed for an actual thermostat. Just somthing to warn me. Like a Light! Very Happy
My scooter already has a thermostat built into the cylinder, and a wire coming from the thermomiter up to my handlebar display, But when I get renthal bars, I wont be having my old dash, Ill have a little speedo and a little fuel gague. Is it possible to wire an LED up to it, and somehow get somthing which will turn it on of the bike is gona overheat....
Ben...
Git
PostPosted: 13:48 - 24 Nov 2004    Post subject: Reply with quote
Anything is achievable binge but junking the factory dash will cost and present a few problems, for new display devices i.e speedo, coolant temperature indicator, fuel, will more than likely require different sensors as to what the manufacturer uses and will quiet frankly be, an interesting and expensive experience Laughing
If you have shed loads of dosh I would love to help develop something Thumbs Up
Even fitting a temperature indicator light from scratch will be rather challenging, it will all be about the sensor and locating it somewhere suitable in the cooling system.
divuk83
PostPosted: 13:56 - 24 Nov 2004    Post subject: Reply with quote
https://www.divuk83.com/images/bike/dials.jpg
I have these on my dragster. Much better to have a temp guage than a light as lights tend to come on way to late and without warning. At least I can see when mine is starting to warm up.
Dave
binge
Emo Kiddy
PostPosted: 14:18 - 24 Nov 2004    Post subject: Reply with quote
kool! Are you interested in selling your dragster? Wink
I think im just gona leave it to be honnest, I want to modify it but I really need to save up for my driving test...
Ben...
divuk83
PostPosted: 14:29 - 24 Nov 2004    Post subject: Reply with quote
I don't really want to sell it at the moment. Maybe this time next year, but even then I doubt it. I will be getting a new bike next year, but I won't be selling the drag to fund it!
Dave
The last post was made 21 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 84.42 Kb
