A Tale of Two MOT's
JonB
Afraid of Mileage
PostPosted: 14:10 - 13 Apr 2013    Post subject: A Tale of Two MOT's Reply with quote
Who said don't trust tyre fitting outfits for MOT's or maintenance?
My wife's new style Mini went in for the annual MOT today. We bought the car second hand about the same time last year and the garage who we bought it off had it MOT'd by a local HiQ centre, another Kwik-Fit, ATS kind of place. Passed the MOT, with advisories on front tyre wear, which I negotiated a new pair of front tyres into the deal. Also it said the front discs and pads were very worn and the rear discs and pads were worn.
I had a look and nothing seemed untoward, I asked a neighbour who does a lot of work on cars, owns a BMW and his missus a new style Mini and he said the discs look fine. So I left it.
Fast forward a year. Took it into our local Mini dealership for the MOT fully expecting a credit card rape for new discs and pads all round. Failed. On a exhaust hanger which I knew was bolloxed. No mention of discs and pads.
Either the Mini garage have missed something, or the HiQ garage last year were trying something on. What's the verdict lads and lasses? Wink
J.M.
PostPosted: 14:41 - 13 Apr 2013    Post subject: Reply with quote
I think most places try it on.
Mum had a fault with her Renault Scenic. I told her it just needed a new spark plug on one of the cylinders. About £5. Explained my reasoning.
She called out a mobile mechanic. Told her exactly the same thing... except added on the fact that she should get them all changed because if 1 went then the others would start going in short fashion. Total bill about £50.
Should have listened to me. Laughing
2004 R1 & 2018 XSR900
Rogue_Shadow
PostPosted: 14:49 - 13 Apr 2013    Post subject: Reply with quote
Never let a Dealership change your tyres, they cost ridiculous amounts of money!
For example, a local garage offered Pilot Road 2 for £110 + £25 fitting
Shocked
Unless it's illegal, take your car elsewhere for the rubber Thumbs Up
dgo1212
PostPosted: 15:03 - 13 Apr 2013    Post subject: Reply with quote
Shocked
Depends on the dealership and the make of tyre, the local Mercedes dealer in town could supply and fit a tyre (I forget the brand) cheper than the place I worked at could.We could do other brands cheaper but he wanted the same brand he was already on. Merc must have a good deal going with the supplier.
Raffles
PostPosted: 15:15 - 13 Apr 2013    Post subject: Re: A Tale of Two MOT's Reply with quote
Didn't they mention anything about the knackered shock absorbers or the dangerously worn steering rack? They usually do.
JonB
Afraid of Mileage
PostPosted: 15:32 - 13 Apr 2013    Post subject: Re: A Tale of Two MOT's Reply with quote
Surprisingly not! I must admit I was pleasantly surprised with the outcome. The Mini is nearly 8 years old and has 71,000 on the clock so around the time when dealerships start quoting suspension bushes etc etc.
Especially when they offering half price MOT's which this was, I suspected there would be a sting in the tail. They even cleaned her car inside and out. Thumbs Up
Codemonkey
PostPosted: 15:43 - 13 Apr 2013    Post subject: Reply with quote
Similar thing happened to me. I have a Toyota Yaris which I've owned from new. Took it in to Gordon Lambs in Sheffield for its annual service & MOT at 4 years old. Received a call later from some tosser saying it would pass the MOT but there was some corrosion on one of the brake pipes which could of course become dangerous Rolling Eyes and which needed treating. They could either replace the pipe (££££££), or apply some "treatment" (£££). I told them if it wasn't a failure not to do anything. They then tried to scam me into paying for new brake fluid to which I argued they could bollox, if the service schedule said it needed changing, it should be included as part of the cost which had already been agreed and that they should change it but that I wouldn't be paying for it Evil or Very Mad
Picked the car up later that day and was told by the scumbag that had phoned me earlier that "oh, we checked and it seems the brake fluid is covered in the cost".
The car has since had 2 more services and MOT's elsewhere, no mention of any corrosion on the brake pipes so draw your own conclusion from that. Needless to say, they've not had any more business from me since Middle Finger
Test Passed 10/05/2011 Current bike: XJ6-N
Nb
PostPosted: 15:45 - 13 Apr 2013    Post subject: Reply with quote
Are you sure it was a spark plug and not a coil? Generally speaking if one plug has gone tits up the others are not far behind, usually due to people not having their car serviced properly.
As for the mini, the mot test standard is supposed to be the same on every mot done wherever. But some testers are on bonus or some may actually try to point out future upcoming problems that they think you need to be aware of. I'm guessing that the place you had it tested at previous were on bonus.
If you find a good mot station stick with it, 99% of my cars are repeat customers.
stuarthouston
PostPosted: 15:51 - 13 Apr 2013    Post subject: Reply with quote
I think all garages are hit or miss until you find one that you can trust.
Last year for example, I took my car for an MOT. It failed on a sticky brake caliper, rear subframe bushes, rear top mounts and a bit of welding. Took it away and did everything bar the welding, which I said they could do when I brought it back for the retest.
When I took it back for the retest (just outwith the 10 day period, thanks to exams), the same guy failed it again, this time on front top-mounts and drive shaft gaiters. The car had covered something like 40 miles in the interim. Absolute cowboys. Thankfully, the place I took my bike to seemed a far more professional establishment, so the car will be going there this year. Thumbs Up
ZebraDriver
PostPosted: 19:20 - 13 Apr 2013    Post subject: Failing MOT on Retest Reply with quote
I had something similar to your experience.
My Range Rover failed its test on a number of items. As I wasn't needing the car urgently I took a month to complete the repairs. Presented it for the retest only for it to fail on two wheel bearings. Now it had been away from the MOT garage for a month but it had only covered a mile in that time - half a mile to the garage and back, so no way had the wheel bearings become loose in that time.
The guy was busy issuing the fail paperwork when I pointed this out to him but he wouldn't budge and an argument ensued as I pointed out that this was unreasonable as they could keep finding one thing after another an keep me coming back and forwards as they "found" more and more things to fail it on - things that they should find on the first test.
I was losing the argument until I asked him for the phone number and details of how to make a complaint to the Ministry, as I pointed out to him, not because my vehicle had failed, with a legitimate fault, but on the fact that the tester had failed to find two faults when it was originally presented for its test.
Suddenly his attitude changed and I was given a pass certificate instead (with the instruction that I was to go and adjust the wheel bearings before I went anywhere with it).
I don't mind having to get an MOT test done - It's a very valid safety check provided that the tester does his job properly.....
ZD
J.M.
PostPosted: 19:30 - 13 Apr 2013    Post subject: Reply with quote
Yup, common fault with the car. Still, for £25 you could get a full set of racing plugs which are known to give better reliability over the normals ones for that car.
Aff
PostPosted: 21:09 - 13 Apr 2013    Post subject: Reply with quote
I always take my car and bike to the council MOT testers.
A bit more strict but they aren't allowed to do any work on it, so don't try and con you.
Electric Bike Project
The last post was made 12 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 78.24 Kb
