| alan0259 |
 alan0259 Nova Slayer
 Posted: 07:24 - 14 Apr 2013 Post subject: Best way to fix vinyl floor to shed base? |
Just wondering if I should use the spray adhesive or use clout nails that you use for roofing felt.
The shed is 12 x 7 and I have a huge roll of 3mm thick vinyl.
The base is made out of 18mm exterior plywood.
Posh shed I know  |
| TUG |
 TUG World Chat Champion
| trevor saxe-coburg-gotha |
| Skudd |
 Skudd Super Spammer
| Raffles |
 Raffles World Chat Champion
| pits |
 pits World Chat Champion
 Posted: 14:28 - 14 Apr 2013 Post subject: |
Use this, with a small notch glue trowel, maybe 0.7mm teeth spread, but not 10kg of it, get a smaller tub
https://www.polymax.co.uk/rubber-adhesive/mapei-vs90-adhesive
First off, cut the floor in till you are happy, then at the entrance to your shed put something heavy on the floor to stop it shifting, then roll the floor back about half way and fold it over and keep it low to the floor when you roll it back or you will crease the floor.
Sweep the floor as best as you can and sweep the back of the flooring as well, you don't want stuff stuck under it. Lay the glue out you don't need a lot at all just good even coverage, glue up the fold and then obviously fold the floor back onto the glue, at this point you really want to use a floor roller little hand held one will do and you want to roll the floor flat and check that there are no air bubbles, get low and look across the floor. If you see an air bubble you need to push it out or the floor will lift.
Move heavy object to the bit you have just glued and repeat all the above for the second half of the floor, don't forget you need to work out the shed but also you need to roll the floor back over.
On that link the adhesive spreader on the right of the page should do
Hand roller
https://compare.ebay.co.uk/like/120876944629?var=lv<yp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y&cbt=y
yes it is expensive, but it will look good and it will last don't nail or staple it down, it will look awful, it will lift and you can tear it if you get it caught. ____________________ Stinkwheel: You have no right to free speech
00:33:00 Blau Zedong: the CB400 is my favourite road bike |
| angryjonny |
 angryjonny World Chat Champion
| alan0259 |
 Posted: 17:54 - 14 Apr 2013 Post subject: |
In the end I bought some evostick adhesive spray and this stuff STICKS
I'll use clout nails in the future if it comes away.
Think i'll get a carpet strip for the entrance as this might start coming away very soon.
Cheers everyone. |
The last post was made 12 years, 351 days ago. Instead of replying here, would creating a new thread be more useful? |
