suzuki ts50x engine/electrical fault
Ajoggy
PostPosted: 19:50 - 15 Apr 2013    Post subject: suzuki ts50x engine/electrical fault Reply with quote
I have a suzuki ts50x and all of a sudden it started playing up, coughing spluttering and dieing as soon as you tried to pull away. I have changed the carb, spark plugs, spark plug cap, cleaned out the fuel tank and tap and the air filter as well at the fuse and spark plug coil but still havent had any luck. Any ideas of what the problem could be?
aceofhearts
PostPosted: 20:02 - 15 Apr 2013    Post subject: Reply with quote
Wrong section, but when i had mine (many years ago) i once kinked the fuel filler vent pipe which meant a vacuum grew in the tank and the bike cut out / wouldnt restart. When you take the fuel tank cap off does it sound like air is being sucked in, and does it run with the filler cap off?
Back to more conventional stuff you have tried:
-Does it spark?
-Is fuel being delivered (is the plug getting wet)?
Ajoggy
PostPosted: 20:38 - 15 Apr 2013    Post subject: ts50 Reply with quote
I have tried all of those things and it still wont run, completly baffled about what it could be. Thanks for the advice tho
Pigeon
PostPosted: 21:33 - 16 Apr 2013    Post subject: Reply with quote
water in fuel tank?
The last post was made 12 years, 313 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 37.59 Kb
