DIY Optimate Cables
Brick_Top
PostPosted: 19:23 - 17 Apr 2013    Post subject: DIY Optimate Cables Reply with quote
Not terribly exciting but may save someone a fair few quid.
I needed to hook my CRX up to my optimate as the alarm drains the battery over a number of weeks, and it isn't getting used at all so it never gets topped up.
I needed a male/female extension cable, and a battery harness (could have used the croc clips but not ideal).
The optimate uses Tamiya large type battery connectors that can be had for pennies on eBay.
The ovaled side of the connector is live.
My optimate charges at 0.8A max so just used some 3A dual core black/red cable.
Crimp the connectors on with a pair of pliers:
https://lh5.googleusercontent.com/-Wef8u5B9h2I/UW7mfJ7SVYI/AAAAAAAADhA/0VpYWnYTT80/w556-h417-p-o/P1020582.JPG
Push the connectors into the plug
https://lh6.googleusercontent.com/-vhL0zKlxV_0/UW7nSsaNZLI/AAAAAAAADhI/sT1EaU0C8yM/w556-h417-p-o/P1020583.JPG
I made a male/female cable, and then a connecting lead with rings for the battery made to length so I could tuck it into the loom:
https://lh4.googleusercontent.com/-d6kyQukpXRs/UW7nfxj6f5I/AAAAAAAADhQ/hRv3VpyKDsI/w557-h417-p-o/P1020584.JPG
The extension cable dangles from the rafters so I can rotate between my bikes and the car.
https://lh4.googleusercontent.com/-pPUuXH1fFyk/UW7nrYAsnhI/AAAAAAAADhY/XKIpHVpD4Oc/w571-h428-p-o/P1020585.JPG
Please note that these cables are made up for charging only. Genuine Optimate cables/harnesses are made of 18AWG cable that will take as many amps as your battery/stator can throw at them... Therefore don't use anything less than 18AWG if you intend to run something off of the cable other than charging your battery... An example may be a optimate to cigarette adapter lead.
R1stu
Shrek!
PostPosted: 20:59 - 17 Apr 2013    Post subject: Reply with quote
I use Deans or XC90 connectors easier to use and better amp rating.
Thumbs Up Very Happy
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
bridgedino
PostPosted: 21:44 - 17 Apr 2013    Post subject: Reply with quote
Car tax has expired Laughing
Brick_Top
PostPosted: 22:40 - 17 Apr 2013    Post subject: Reply with quote
how are they compatible with an optimate?
I will add an inline fuse to the battery harness to protect the cable.
R1stu
Shrek!
PostPosted: 23:00 - 17 Apr 2013    Post subject: Reply with quote
U cut them off and replace!
The last post was made 13 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 47.16 Kb
