XR250 Project
at106
PostPosted: 19:52 - 21 Apr 2013    Post subject: XR250 Project Reply with quote
I bought this bike off of a forum member as it was cheap (ish) although i dont really have the space for another bike Laughing So once it's running i plan to either sell it, or keep it and sell my dr350.
I was told by the previous owner that it basically needed a top end rebuild, however upon arrival it looked a lot better than i first thought. It arrived to me with the piston and cam chain removed and the engine loosely bolted together so i quickly stripped it back down.
https://i448.photobucket.com/albums/qq202/at106/027-1_zpsc6c9efaa.jpg
https://i448.photobucket.com/albums/qq202/at106/028_zps23450545.jpg
https://i448.photobucket.com/albums/qq202/at106/029-1_zps6ece4cee.jpg
https://i448.photobucket.com/albums/qq202/at106/032_zps85db7ff5.jpg
It needs a good clean but already im starting to like it due to it's simplicity.
https://i448.photobucket.com/albums/qq202/at106/035-1_zps982831ee.jpg
https://i448.photobucket.com/albums/qq202/at106/036-1_zps4fdd81d6.jpg
https://i448.photobucket.com/albums/qq202/at106/033-1_zps2754b409.jpg
I then removed the cylinder head and the cylinder and all looked good. I was expecting the piston and cylinder to be scored (as i was told it needed a new piston) but luckily it was all ok. I measured the bore, piston and piston ring end gaps and decided it just needed a new set of rings.
The piston is a 77mm wiseco piston taking the engine upto 266cc.
https://i448.photobucket.com/albums/qq202/at106/023-2_zpsbedd00da.jpg
https://i448.photobucket.com/albums/qq202/at106/024-2_zps29451f2b.jpg
The reason the cam chain was removed is because it needs replacing, as you can see in these pictures it's eat away at the tunnel!
https://i448.photobucket.com/albums/qq202/at106/041-1_zps7b5f801b.jpg
https://i448.photobucket.com/albums/qq202/at106/039-1_zps9f87b8d3.jpg
But that can be easily fixed. The only issue i've found so far is that the inlet valves are very worn although i've read that it's very common. So i'll probably be replacing them with a set of wiseco steel valves. That's all for now until parts turn up Thumbs Up
Fizzer Thou
PostPosted: 23:25 - 24 Apr 2013    Post subject: Reply with quote
Looks good.Do not forget to hone the bore lightly before installing new piston rings.I helped a friend with a similar engine project in the early part of last year (2012).
https://www.bikechatforums.com/viewtopic.php?t=234319&highlight=xr250
Always have a 'Plan B'
at106
PostPosted: 07:28 - 25 Apr 2013    Post subject: Reply with quote
Thanks Thumbs Up yeah I've honed the bore, hopefully the rest of the parts will arrive tomorrow so it might be running this weekend!
at106
PostPosted: 10:25 - 04 May 2013    Post subject: Reply with quote
Last week the remaining parts arrived so i could get the engine back together.
https://i448.photobucket.com/albums/qq202/at106/Picture840_zpseba37a50.jpg
The bore was honed and the piston and rings fitted, i also removed the clutch so the new cam chain could be fitted.
https://i448.photobucket.com/albums/qq202/at106/Picture830_zps18dd5066.jpg
https://i448.photobucket.com/albums/qq202/at106/Picture828_zps1f37e879.jpg
I decided the intake valves weren't as bad as i first thought so they're staying for now. After lapping them in they looked a lot better.
https://i448.photobucket.com/albums/qq202/at106/Picture836_zps1b440859.jpg
https://i448.photobucket.com/albums/qq202/at106/Picture835_zpsa5703288.jpg
https://i448.photobucket.com/albums/qq202/at106/Picture841_zpsb83ea2fd.jpg
Next i fitted the cam chain, camshaft, cylinder head cover and set the valve clearances however i forgot to take pictures Laughing
I changed the oil filter and filled it up with oil and it started after a few kicks, however there was a serious oil leak from the clutch cover gasket.
https://i448.photobucket.com/albums/qq202/at106/Picture843_zps2919cdd4.jpg
https://i448.photobucket.com/albums/qq202/at106/Picture844_zps3e294e4b.jpg
A new gasket sorted that and now it's been running perfectly for the last 100km and i think im going to keep it Thumbs Up I'll get some more pictures next time i take it out.
waffles
PostPosted: 15:38 - 04 May 2013    Post subject: Reply with quote
I have a soft spot for xr's, its good to see another one fixed up Thumbs Up
thx1138
PostPosted: 17:39 - 07 May 2013    Post subject: Reply with quote
cool glad you fixed it up, hope you make some money, or enjoy riding it, either way rather it was still on the road than at a breakers yard. Thumbs Up Pick up my new Honda on Saturday. Mr. Green
p.s better change my avatar now
The last post was made 13 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 53.66 Kb
