| EazyDuz |
 EazyDuz World Chat Champion
 Posted: 16:43 - 22 Apr 2013 Post subject: |
1) Yes. If they are blued (as sometimes happens when they've been slipping) you can deglaze them on a sheet of fine, wet, wet and dry paper stuck to a sheet of glass with water. Use a side to side movement, not a circular one. Clean them THOROUGHLY in solvent afterwards.
2) Carefully.
I use a stanley knife blade with a piece of PVC tape stuck across the back. Take care because you can easily slice lumps out of the alloy too, keep it perfectly level with the gasket surface.
You can also make a gasket scraper by cutting a 1/2" slot down the end of a bit of copper pipe, opening it out and hammering it flat.
3) Yes. If they are crossheads, it's worth replacing them with socket heads. Be very careful not to overtighten them, they usually only need 7.5ft/lb which is pretty much one finger on an allen key and below the scale of most torque wrenches. This is one place I think stainless is entirely appropriate because they are very understressed fastners.
4) I doubt very much it'll cause a problem even if they are all in the wrong place.
If they are aftermarket plates, I'd be tempted to do a short-interval oil and filter change once they're bedded in and check for any bits floating in the oil you drain. Maybe pointless but I've known some aftermarket ones to be somewhat "hairy" and leave a load of bits floating in the oil which are bound to gum up the filter over time. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 17:21 - 22 Apr 2013 Post subject: |
Stinkwheel.
........listen look read learn visualise......absorb......love your posts stinkwheel.....
AFMS i'd keep coppergrease away from anything that could let alloy and steel conduct electricity, ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| EazyDuz |
| EazyDuz |
| EazyDuz |
| unitynotsocri... |
 Posted: 18:30 - 22 Apr 2013 Post subject: |
i usually stuff some clean rag inside the casing and after using my scrapers,use medium to rough sandpaper wrapped in a small flat peice of steel and a small file.
its easy to get p8888ed off with it and rush,but you run the danger of ruining the gasket surface ,especially with metal scapers or smaller screwdrivers,ally can peel off like butter. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| EazyDuz |
| EazyDuz |
The last post was made 12 years, 242 days ago. Instead of replying here, would creating a new thread be more useful? |
