So...radiator fan...trouble shoot help
Shinigami
PostPosted: 18:45 - 22 Apr 2013    Post subject: So...radiator fan...trouble shoot help Reply with quote
Reet, looks like i've another lil problem on the hornet, noticed I felt a bit warm round the legs this eve riding home from work, noticed the temp gauge was actually in the red, when stopped it looks as though the radiator fan isn't coming on.
What am I looking at for troubleshooting?
bridgedino
PostPosted: 18:55 - 22 Apr 2013    Post subject: Reply with quote
Coolant level, fuse?
Shinigami
PostPosted: 19:24 - 22 Apr 2013    Post subject: Reply with quote
hmm oddly, just cleaned out the connector to the fan, got the bike hot and the fan kicked in this time, hopefully it was just being a dick and just needed cleaning
bridgedino
PostPosted: 21:58 - 22 Apr 2013    Post subject: Reply with quote
Does your bike heat up quickly? The fans on my previous two CBF's only ever came on in July and August.
Rest of the year they collected cobwebs
Shinigami
PostPosted: 06:51 - 23 Apr 2013    Post subject: Reply with quote
not really the bikes only just started getting towards the top of the gauge since it warmed up a bit out. over the winter it barely crept above the C mark.
Fan seems to kick in quite high on the gauge though, no idea if that's when it's supposed to or not though Laughing
andym
PostPosted: 08:34 - 23 Apr 2013    Post subject: Reply with quote
Not sure if that's just your bike or not, but every temperature gauge I've ever seen usually kicks in about half way (all my cars and bikes).
Have you checked if there is any air in the cooling system? Or even a slight water leak can affect the pressure and cause the reading to be high. I've found topping the water up then squeezing the hoses with the cap on a few times shifts the air up.... then top up water and repeat until it doesn't take any more.
Also it might be worth checking your thermostat in a pot of (almost) boiling water
Shinigami
PostPosted: 08:55 - 23 Apr 2013    Post subject: Reply with quote
i'll have a look at the service manual at where the thermostat is to take it off and have a ganders Thumbs Up
noobRider
PostPosted: 09:24 - 23 Apr 2013    Post subject: Reply with quote
I don't know about on a bike but I had a similar problem in my car where the pin that holds the mechanism that engages the fan had seized and was stopping the fan engaging. Like you my car ran very cool over Winter and only really started needing the fan in Summer or when I was towing. A good whack might clear it or taking it apart and lubricating it.
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
Shinigami
PostPosted: 09:32 - 23 Apr 2013    Post subject: Reply with quote
Fan spins absolutely fine and is working fine again Thumbs Up just gonna look at the point it kicks in when I can be bothered as it doesn't turn on until the gauge is pretty high, doesn't get into the red on my daily riding though and on motorways & dual carriageways stays nice and low
moonzoomer
PostPosted: 15:23 - 23 Apr 2013    Post subject: Reply with quote
remove the stat and put it in a pot of water, connect a multi meter across the 2 terminal of the stat set to the Ohms or audio range, turn on the heat and measure the temp of the water with a thermometer to see when the stat goes to closed circuit.
The last post was made 12 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 63.3 Kb
