Am I damaging my bike with my restrictors?
daz_app
PostPosted: 19:24 - 23 Apr 2013    Post subject: Am I damaging my bike with my restrictors? Reply with quote
Ok, so last week, I was covering for another member of staff at our Burton offices, some 40-odd miles commute either way in massive headwinds and gusts.
I've got a restrictor kit in my CBF600 (inlet washers), and along the A50 (the shittiest road surface known to man), I noticed that at about 70 or 80ish, my rev counter was up at 6000rpm for a majority of the time. This was in top gear. I would have expected it to be lower for some reason, but have limited experience...
Is this going to damage the bike or put undue wear and tear on the engine, chain etc.?
Also, what is the normal rpm for the speed in top gear for a four cylinder 600?
Oh and before anyone asks, the restrictors are likely to fall out soon...
Thanks in advance...
our bike family...Wanda - CBF600
Vera - Suzuki RV125 Van Van - now sold! Sad
Maureen - Suzuki GZ125 Marauder
dragstaar
PostPosted: 19:28 - 23 Apr 2013    Post subject: Reply with quote
no, that is normal.
the washers restrict the airflow, so that there'd less oxygen to burn.
So what you'll find is that the biggest difference is the acceleration. You'll get to the speed you want, it'll just take longer to get there.
remember, bikes tend to rev higher than cars. 6K revs, 70mph, top gear...sounds right to me.
Slacker24seve...
PostPosted: 20:47 - 23 Apr 2013    Post subject: Reply with quote
What, you mean they haven't fallen out yet?
Banger rallies are ace
daz_app
PostPosted: 20:58 - 23 Apr 2013    Post subject: Reply with quote
Nope not yet. I've ridden my bike throughout the winter for my usual 4.5 mile commute, and with the weather starting to turn warmer, I can certainly say that I've become far more confident and relaxed on the bike...
However, the last weeks longer commute has really wheted my appetite for MOAR SPEED!!!! Very Happy
PostPosted: 21:03 - 23 Apr 2013    Post subject: Re: Am I damaging my bike with my restrictors? Reply with quote
Seems fine.
What does your bike redline at?
If we take it to be 12000rpm for ease say, that gives us 140mph to 160mph geared top speed, depending on whether that 6000rpm was at 70 or 80.
Doubt it'll hit 160, so wouldn't want it any higher than that.
Shouldn't cause any damage - just like you're riding while not really opening the throttle much.
Wonko The Sane
PostPosted: 22:26 - 23 Apr 2013    Post subject: Reply with quote
I currently ride a 125 varadero round the M60ring to get to work, I don't watch the speedo, I watch the rev counter as it sits at the 12000 red line when I'm doing 70ish I'm watching to make sure I don't bump it of the limiter too much.
If you didn't rev a small bike engine then you'd go nowhere.
As previously state, bike engines are designed as high performance engines, designed to be revved.
andym
PostPosted: 22:33 - 23 Apr 2013    Post subject: Reply with quote
Because I'm still running in the engine on the zxr (if I could actually get it to run for more than a day at a time that is), that has only been up to 6.5k which is about 85-90.
GrumpyGuts
PostPosted: 22:42 - 23 Apr 2013    Post subject: Reply with quote
Mine does 5,500 rpm circa 70 mph in 6th. Pretty normal (and that's restricted)
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
Derivative
PostPosted: 22:44 - 23 Apr 2013    Post subject: Reply with quote
CB5 sits at 5500rpm all day (70mph in top gear).
DrSnoosnoo
PostPosted: 08:22 - 24 Apr 2013    Post subject: Reply with quote
As said above.
On my ZZR600 I know I'm in top gear when I've got 6k revs at 70 mph
DrDonnyBrago
PostPosted: 09:24 - 24 Apr 2013    Post subject: Reply with quote
80 on my CBR600f is just over 6.5k in 6th.
70 is about 6k.
Snorty
PostPosted: 09:26 - 24 Apr 2013    Post subject: Reply with quote
Yes you're damaging it. The only way to reverse any damage done and prevent future damage is to remove the restrictors immediately.
Failing to do this could cause catastrophic failures such as a twisted subframe or a loose chain.
Gazza M
PostPosted: 09:55 - 24 Apr 2013    Post subject: Reply with quote
having restrictors in won't change the gearing - this is what determines what rpm you'll be doing at a certain speed!
Past: '07 YBR125, '00 GPZ500S, '99 ZRX1100, '98 CBR600 track bike, '97 ZX9R
Present: '05 R6 track bike, 140 pit bike
Rob1970
PostPosted: 12:38 - 24 Apr 2013    Post subject: Reply with quote
I have an 06 restricted (25KW/33bhp) CBF600 and it sits at 6k revs at 75-80 just like yours.
BTW do you have a load of vibrations at 5k before it smooths out at 6-7k?
daz_app
PostPosted: 20:41 - 24 Apr 2013    Post subject: Reply with quote
Rob, I can't say I've noticed but i'll check it out tomorrow...
Thanks all for the advice/general low level pisstaking! Very Happy Karma
Teflon-Mike
tl;dr
PostPosted: 21:37 - 24 Apr 2013    Post subject: Reply with quote
My bike is pulling 11,000 rpm at 70mph in top........ Wink
Bikes rev.
Restrictors are just like not letting the throttle open all the way.
Means less likely to cause damage, not more.
The last post was made 12 years, 256 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 89.68 Kb
