How Do I Find The Age Of My Lid?
synaptyx
PostPosted: 23:02 - 25 Nov 2004    Post subject: How Do I Find The Age Of My Lid? Reply with quote
I've found a ticket inside that's laid out like this:
050001 - P
E6
003 - 0529
There's also a sticker on the side of the visor:
CROSS S.A.
E6 05 0001
It's a Laser Revolution.
Ta! Smile
yambabe
PostPosted: 23:19 - 25 Nov 2004    Post subject: Reply with quote
Er..... by remembering when you bought it? Confused
And if you didn't buy it new, it's irrelevant cos you should chuck it in the bin, or grow flowers in it or something!
synaptyx
PostPosted: 23:21 - 25 Nov 2004    Post subject: Reply with quote
Um, must be coming up for two years ago, but it was discounted to £149 from £220. Whatever that means. Confused Second hand? Gimme a break, I'm thick not er... thick. Wink
yambabe
PostPosted: 23:23 - 25 Nov 2004    Post subject: Reply with quote
Aha, so it's two-years-plus-however-long-it-had-been-on-the-shelf old then!
easy! Thumbs Up
synaptyx
PostPosted: 23:27 - 25 Nov 2004    Post subject: Reply with quote
Um, yeah, I got that. Are they not meant to have manufacture dates on them?
craigie b
Citizen Smith
PostPosted: 23:28 - 25 Nov 2004    Post subject: Re: How Do I Find The Age Of My Lid? Reply with quote
050001 - P
E6
003 - 0529
CROSS S.A.
E6 05 0001
Ta! Smile
Ye fecking neep! Wink
synaptyx
PostPosted: 23:30 - 25 Nov 2004    Post subject: Reply with quote
It was kind of the date of manufacture I was after. I thought that counted more than the length of time you actually owned the lid. I posted all the info that's on the lid, but it doesn't really tell you much.
flat spot
PostPosted: 00:14 - 26 Nov 2004    Post subject: Reply with quote
Have a look on the straps. There is usually an embossed date which is the manufacture date. BTW, that is the only date that counts.
Flip
PostPosted: 00:21 - 26 Nov 2004    Post subject: Reply with quote
Cut the top off so it's only the base and count the rings. Thumbs Up
[EDIT] B*llocks, thats trees.
craigie b
Citizen Smith
PostPosted: 00:34 - 26 Nov 2004    Post subject: Reply with quote
I know what you talking about, when I went for my lid I was told it had a 5 year life cos it was fibreglass. I think its once you start wearing it that the fibreglass begins to suffer wear n tear and pollutants might break down its structure. Dunno!
synaptyx
PostPosted: 09:18 - 26 Nov 2004    Post subject: Reply with quote
It was on the strap. 1999. Fuck. Shocked and my cheapo FM AX is 2001. Confused
T.C
PostPosted: 10:45 - 26 Nov 2004    Post subject: Reply with quote
Age of manufacture doesn't matter a jot, it is the amount of time it has beenm in use since it was purchased that is important.
Most Japanese helmets are at least 18 months old before they even get to the UK, and until recently when self certification was introduced, they would sit in a bonded warehouse whilst a selection were sent off to BSI for testing.
Look at the january issue of Motorcycle Voyager, where all will be explained in respect of manufacture, fit, life of a helmet and so on.
As a general rule though, the date of manufacture is usualy on a label either stitched to the comfort liner or attached to the styrofoam liner under the comfort liner!
It is better to arrive 30 seconds late in this world, than 30 years early in the next
synaptyx
PostPosted: 13:49 - 26 Nov 2004    Post subject: Reply with quote
Asking about provided this info. I realise it's from American organisations, but I found it interesting. It would seem to contradict your asserstion that the age of manufacture doesn't matter a jot.
"…glues, resins and other materials used in helmet production can affect liner materials, and general liner deterioration and helmet degradation can result from hair oils, body fluids, cosmetics, and normal "wear and tear." (Snell Foundation)
… recommend that helmets be replaced after five years since exposure to ultraviolet light may cause invisible deterioration (New Jersey Dept of Transportation)"
T.C
PostPosted: 14:00 - 26 Nov 2004    Post subject: Reply with quote
Read what I said! The age of manufacturer is unimportant, it is the time it has been in use as the liners react to heat and sweatm although the shell does not decompose, the liner will eventually become like a lump of concrete which is why a life of 5 years is recommended. However, the fact that it has been in its box and stored in a cool area will not start it degrading, it is when it is out in the open and in use that the process starts.
This is why when trying a new helmet off the shelf, always purchase one in its box as the degradation process will not yet have started, and it will ensure a proper fit as no one is likely (or at least the risk is less) of it having become mishapen because of people constantly trying it on.
I am off to Japan to the Shoei (and Arai) factory soon, I am sure that they will have their observations to make!
synaptyx
PostPosted: 14:08 - 26 Nov 2004    Post subject: Reply with quote
I did read what you said, but depending on how you read what I posted, you could come to the conclusion that it is implied that even before the helmet is worn... "...glues, resins and other materials used in helmet production can affect liner materials, and general liner deterioration" Also, if a helmet is stored in a shop, you can't assume it's been kept in strict adherence to any possible storage guidelines the manufacturer might recommend.
I see what you're saying T.C, but I'm not convinced. Thanks for the info though, and it would be very interesting to hear the thoughts of the Shoei/Arai manufactuers. Smile
T.C
PostPosted: 18:40 - 26 Nov 2004    Post subject: Reply with quote
synaptyx wrote:
I'm not convinced
You obviously know the subject then and sounds like all the research and reports I do for Government bodies along with 20 years experience of examing motorcycle clothing (particularly crash helmets) post accident has been wasted then, Wink
synaptyx
PostPosted: 22:15 - 26 Nov 2004    Post subject: Reply with quote
Dammit man shurrup! You're making it difficult for me trying to convince the wife I need a new lid! Wink
Fortuna
PostPosted: 03:36 - 27 Nov 2004    Post subject: Reply with quote
Mine has a nice label sewn in with the date of manufacture.
The last post was made 21 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 99.84 Kb
